Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - till required to logon after ten minutes of inactivity. Any help.
Old 02-24-2008   #1 (permalink)
Glenn
Vista-when the computer is inactive for ten minutes it requres that I logon
again when I want to resume use of the computer. I right clicked on the
desktop, chose Personalize, Chose Screen Saver and removed the check mark
next to On Resume, Display Logon Screen option. However I am still required
to logon. Any help?
Old 02-24-2008   #2 (permalink)
Rick Rogers
Re: till required to logon after ten minutes of inactivity. Any help.
Go to the Control Panel/Power Options, click the line to change the plan
settings. Then click the line to "change advanced power settings". In this
section, under Additional Settings, you will find an option to disable the
password requirement.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Glenn" <Glenn@xxxxxx> wrote in message
news:A2C632E0-5665-4C65-90B7-D21F22622B39@xxxxxx
> logon
> required
> to logon. Any help?
the mask logon appearsafter 20 minutes Vista General
Additional Logon Information Required? Vista networking & sharing
Vista Offline Files Consuming 100% CPU for 2 minutes every few minutes Vista General
Can't send/receive. Logon authentication required Vista mail
How do I stop the screen going blank after several minutes inactivity? Vista performance & maintenance
