Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista Tutorial - Product Key Problems
Old 02-28-2008   #1 (permalink)
Robert
Guest
I bought windows vista ultimate in may of 2007 to upgrade from XP, it ran
fine until feb 2008, when my graphics card failed and i thought my windows
messed up, causing me to erase windows, so i had to take it to Data Doctors
to get XP back on so i could upgrade to Vista, well now its not letting me
activate my windows because my product key is already in use and im using the
same key from my Ultimate box!
Old 02-28-2008   #2 (permalink)
Dustin Harper
Guest
Re: Product Key Problems
You can select Activate by Phone, and give Microsoft a call and they will
get you activated and back up and running. Basically, it shows that it is
already in use because you had it installed and activated previously.
Dustin Harper
dharper@xxxxxx
http://www.vistarip.com | Vista Resource & Information Page
"Robert" <Robert@xxxxxx> wrote in message
news:72285B24-06AA-4CB7-A57B-9A69B5D003E2@xxxxxx
> windows
> Doctors
> the
Old 02-28-2008   #3 (permalink)
Carey Frisch [MVP]
Guest
You can reset your Windows Vista activation by performing the following:
1. Click on the Start button and in the Start Search box type in: slui.exe 4
2. Press the Enter key on your keyboard.
3. Select your Country.
4. Follow the instructions for phone activation.
5. Once completed, restart your computer.
Carey Frisch
Microsoft MVP
Windows Shell/User
Product Key problems Vista account administration
Product Problems with Vista Vista General
product key problems Vista General
Annoying product key problems Vista hardware & devices
Product ID problems Vista General
