| Guest | Problem with the installation of Vista x64 Ultimate During the installation of Vista Ñ…64 Ultimate, after the "Expand of files", "Install of features" and so on the computer wants to restart. During the restart the following message appears: "Windows failed to start. A recent hardware or software change might be the cause. To fix the problem: 1. Insert your Windows installation disc and restart your computer. 2. Choose your language settings and click "Next". 3. Click "Repair your computer". If you do not have this disk, contact your system administrator or computer manufacturer for assistance. File: \Windows\system32\drivers\acpi.sys Status: 0xc0000221 Info: Windows failed to load because a critical system driver is missing or corrupt." Then after running the "Startup Repair", the following message appears: "Startup Repair cannot repair this computer automatically." My computer is: Dell Dimension E521. AMD 64 x2 5600+ 2.8 GHz RAM 4GB Video card: GeForce 8600 GT 512 MB Apart the video card, I have a Modem card (purchased together with the computer), Internet card and Card Reader (inserted additionally). Please help me solve the problem! Best regards! V. Zlatanov. |
| Guest | Re: Problem with the installation of Vista x64 Ultimate There are a number of possibilities. Check the ACPI settings in the BIOS and update the it if it is more than 2-3 years old. Some computers will not install Vista with 4 gig ram. Remove 2 gig for the install. There is a hotfix that then needs to be applied and then you can install the other 2 gig back. Install the driver for your video card either at the load drivers or during the last reboot, using F8 "Венци Златанов" <@discussions.microsoft.com> wrote in message news:AB91FD30-EBC5-416A-A5CE-7D3DA16761FA@xxxxxx Quote: > During the installation of Vista х64 Ultimate, after the "Expand of > files", > "Install of features" and so on the computer wants to restart. During the > restart the following message appears: > > "Windows failed to start. A recent hardware or software change might be > the > cause. To fix the problem: > 1. Insert your Windows installation disc and restart your computer. > 2. Choose your language settings and click "Next". > 3. Click "Repair your computer". > If you do not have this disk, contact your system administrator or > computer > manufacturer for assistance. > > File: \Windows\system32\drivers\acpi.sys > Status: 0xc0000221 > Info: Windows failed to load because a critical system driver is missing > or > corrupt." > > Then after running the "Startup Repair", the following message appears: > > "Startup Repair cannot repair this computer automatically." > > My computer is: > Dell Dimension E521. > AMD 64 x2 5600+ 2.8 GHz > RAM 4GB > Video card: GeForce 8600 GT 512 MB > > Apart the video card, I have a Modem card (purchased together with the > computer), Internet card and Card Reader (inserted additionally). > > Please help me solve the problem! > Best regards! > V. Zlatanov. > |
| Vista ultimate installation problem on Sony vaio VGN-NR31J | Vista installation & setup | |||
| Windows Vista Ultimate x64 Bit Installation Problem | Vista installation & setup | |||
| Re-installation of Vista Ultimate | Vista installation & setup | |||
| Vista x64 Ultimate>>Installation problem | Vista installation & setup | |||
| New Vista Ultimate Installation | Vista installation & setup | |||
