| | Problem with unattended installation When I try to do an unattended installation on a specialized computer that we have built, the Vista installation gets to the Copy files section, and then gives the following error: Windows could not prepare the computer to boot into the next phase of installation I know that the setup has partitioned and formatted my harddrive because I start with a blank hard drive, and when I get to that error message and reboot, I see that the drive is now formatted. However, if I do the installation manually on the exact same computer, I don't get this error, and the installation will finish successfully. I am using the new OEM Vista SP1 installation disk. Below are the contents of my autounattend.xml file (with the product key modified). Any suggestions would be appreciated. <?xml version="1.0" encoding="utf-8" ?> - <unattend xmlns="urn:schemas-microsoft-com:unattend"> - <settings pass="windowsPE"> - <component name="Microsoft-Windows-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> - <DiskConfiguration> - <Disk wcm:action="add"> - <CreatePartitions> - <CreatePartition wcm:action="add"> <Order>1</Order> <Type>Primary</Type> <Extend>true</Extend> </CreatePartition> </CreatePartitions> - <ModifyPartitions> - <ModifyPartition wcm:action="add"> <Active>true</Active> <Extend>false</Extend> <Format>NTFS</Format> <Label>ELOVISTA</Label> <Letter>C</Letter> <Order>1</Order> <PartitionID>1</PartitionID> </ModifyPartition> </ModifyPartitions> <DiskID>0</DiskID> <WillWipeDisk>true</WillWipeDisk> </Disk> <WillShowUI>OnError</WillShowUI> </DiskConfiguration> - <UserData> - <ProductKey> <Key>XXXXX-XXXXX-XXXXX-4f48j-cfbbc</Key> <WillShowUI>OnError</WillShowUI> </ProductKey> <AcceptEula>true</AcceptEula> </UserData> - <ImageInstall> - <OSImage> - <InstallTo> <DiskID>0</DiskID> <PartitionID>1</PartitionID> </InstallTo> <WillShowUI>OnError</WillShowUI> <InstallToAvailablePartition>true</InstallToAvailablePartition> </OSImage> </ImageInstall> - <Display> <HorizontalResolution>800</HorizontalResolution> <VerticalResolution>600</VerticalResolution> <ColorDepth>32</ColorDepth> </Display> </component> - <component name="Microsoft-Windows-International-Core-WinPE" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> - <SetupUILanguage> <UILanguage>en-us</UILanguage> </SetupUILanguage> <InputLocale>0409:00000409</InputLocale> <SystemLocale>en-us</SystemLocale> <UILanguage>en-us</UILanguage> <UserLocale>en-US</UserLocale> </component> </settings> - <settings pass="oobeSystem"> - <component name="Microsoft-Windows-Deployment" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> - <Reseal> <Mode>Audit</Mode> <ForceShutdownNow>false</ForceShutdownNow> </Reseal> </component> </settings> - <settings pass="specialize"> - <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> - <OEMInformation> <Manufacturer>Elo TouchSystems</Manufacturer> <Model>ESY17A2</Model> <SupportHours>9AM - 5PM PST</SupportHours> <SupportPhone>1-800-ELOTOUCH</SupportPhone> <SupportURL>www.elotouch.com</SupportURL> </OEMInformation> - <Display> <HorizontalResolution>800</HorizontalResolution> <VerticalResolution>600</VerticalResolution> <ColorDepth>32</ColorDepth> </Display> </component> </settings> <cpi fflineImage cpi:source="catalog:z:/sbc6/vista imagefiles/install_windows vista ultimate.clg" xmlns:cpi="urn:schemas-microsoft-com:cpi" /> </unattend> |
| | RE: Problem with unattended installation Hello, Take a look at this article it seems to apply to your scenario: 942975 Error message when you specify the value of the InstallToAvailablePartition XML element as "true" in the Unattend.xml file to install Windows Vista: "Windows could not prepare the computer to boot into the next phase of installation" http://support.microsoft.com/default...b;EN-US;942975 Thanks, Darrell Gorter[MSFT] This posting is provided "AS IS" with no warranties, and confers no rights -------------------- | >Thread-Topic: Problem with unattended installation | >thread-index: Aciu5ozGAWqpltrRRv+h+pBeP2aH8w== | >X-WBNR-Posting-Host: 198.175.154.213 | >From: =?Utf-8?B?VnVvbmcgTmd1eWVu?= <VuongNguyen@xxxxxx> | >Subject: Problem with unattended installation | >Date: Mon, 5 May 2008 12:31:00 -0700 | >Lines: 121 | >Message-ID: <BC1F26A1-1A46-4E69-BE80-BC6A7957D0D2@xxxxxx> | >MIME-Version: 1.0 | >Content-Type: text/plain; | > charset="Utf-8" | >Content-Transfer-Encoding: 7bit | >X-Newsreader: Microsoft CDO for Windows 2000 | >Content-Class: urn:content-classes:message | >Importance: normal | >Priority: normal | >X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2992 | >Newsgroups: microsoft.public.windows.vista.installation_setup | >Path: TK2MSFTNGHUB02.phx.gbl | >Xref: TK2MSFTNGHUB02.phx.gbl microsoft.public.windows.vista.installation_setup:39420 | >NNTP-Posting-Host: tk2msftibfm01.phx.gbl 10.40.244.149 | >X-Tomcat-NG: microsoft.public.windows.vista.installation_setup | > | >When I try to do an unattended installation on a specialized computer that we | >have built, the Vista installation gets to the Copy files section, and then | >gives the following error: | > | >Windows could not prepare the computer to boot into the next phase of | >installation | > | >I know that the setup has partitioned and formatted my harddrive because I | >start with a blank hard drive, and when I get to that error message and | >reboot, I see that the drive is now formatted. | > | >However, if I do the installation manually on the exact same computer, I | >don't get this error, and the installation will finish successfully. I am | >using the new OEM Vista SP1 installation disk. Below are the contents of my | >autounattend.xml file (with the product key modified). Any suggestions would | >be appreciated. | > | > <?xml version="1.0" encoding="utf-8" ?> | >- <unattend xmlns="urn:schemas-microsoft-com:unattend"> | >- <settings pass="windowsPE"> | >- <component name="Microsoft-Windows-Setup" processorArchitecture="x86" | >publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" | >xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" | >xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> | >- <DiskConfiguration> | >- <Disk wcm:action="add"> | >- <CreatePartitions> | >- <CreatePartition wcm:action="add"> | > <Order>1</Order> | > <Type>Primary</Type> | > <Extend>true</Extend> | > </CreatePartition> | > </CreatePartitions> | >- <ModifyPartitions> | >- <ModifyPartition wcm:action="add"> | > <Active>true</Active> | > <Extend>false</Extend> | > <Format>NTFS</Format> | > <Label>ELOVISTA</Label> | > <Letter>C</Letter> | > <Order>1</Order> | > <PartitionID>1</PartitionID> | > </ModifyPartition> | > </ModifyPartitions> | > <DiskID>0</DiskID> | > <WillWipeDisk>true</WillWipeDisk> | > </Disk> | > <WillShowUI>OnError</WillShowUI> | > </DiskConfiguration> | >- <UserData> | >- <ProductKey> | > <Key>XXXXX-XXXXX-XXXXX-4f48j-cfbbc</Key> | > <WillShowUI>OnError</WillShowUI> | > </ProductKey> | > <AcceptEula>true</AcceptEula> | > </UserData> | >- <ImageInstall> | >- <OSImage> | >- <InstallTo> | > <DiskID>0</DiskID> | > <PartitionID>1</PartitionID> | > </InstallTo> | > <WillShowUI>OnError</WillShowUI> | > <InstallToAvailablePartition>true</InstallToAvailablePartition> | > </OSImage> | > </ImageInstall> | >- <Display> | > <HorizontalResolution>800</HorizontalResolution> | > <VerticalResolution>600</VerticalResolution> | > <ColorDepth>32</ColorDepth> | > </Display> | > </component> | >- <component name="Microsoft-Windows-International-Core-WinPE" | >processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" | >language="neutral" versionScope="nonSxS" | >xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" | >xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> | >- <SetupUILanguage> | > <UILanguage>en-us</UILanguage> | > </SetupUILanguage> | > <InputLocale>0409:00000409</InputLocale> | > <SystemLocale>en-us</SystemLocale> | > <UILanguage>en-us</UILanguage> | > <UserLocale>en-US</UserLocale> | > </component> | > </settings> | >- <settings pass="oobeSystem"> | >- <component name="Microsoft-Windows-Deployment" processorArchitecture="x86" | >publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" | >xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" | >xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> | >- <Reseal> | > <Mode>Audit</Mode> | > <ForceShutdownNow>false</ForceShutdownNow> | > </Reseal> | > </component> | > </settings> | >- <settings pass="specialize"> | >- <component name="Microsoft-Windows-Shell-Setup" | >processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" | >language="neutral" versionScope="nonSxS" | >xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" | >xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> | >- <OEMInformation> | > <Manufacturer>Elo TouchSystems</Manufacturer> | > <Model>ESY17A2</Model> | > <SupportHours>9AM - 5PM PST</SupportHours> | > <SupportPhone>1-800-ELOTOUCH</SupportPhone> | > <SupportURL>www.elotouch.com</SupportURL> | > </OEMInformation> | >- <Display> | > <HorizontalResolution>800</HorizontalResolution> | > <VerticalResolution>600</VerticalResolution> | > <ColorDepth>32</ColorDepth> | > </Display> | > </component> | > </settings> | > <cpi fflineImage cpi:source="catalog:z:/sbc6/vista image| >files/install_windows vista ultimate.clg" | >xmlns:cpi="urn:schemas-microsoft-com:cpi" /> | > </unattend> | > |
| Unattended Software installation | Vista General | |||
| Unattended Software installation | Vista account administration | |||
| unattended installation over the network? | Vista installation & setup | |||
| Unattended installation issue | PowerShell | |||
| Unattended installation of MSMQ | Vista installation & setup | |||
