Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Internal Sound is working but no sound for headphones
Old 09-04-2006   #1 (permalink)
=?Utf-8?B?UGllcnJlRGE=?=
Hi there,
I use Vista Pre-RC1 and installed it without problem. Working fine right now.
I have just a problem with external sound.
As my internal sound and speakers works well, I can't have sound on my jack
where I can connect external speakers or headphones ... NO WAY !!
Any solutions will be welcom ...
Best regards
Pierre
Old 09-12-2006   #2 (permalink)
=?Utf-8?B?amFzb24=?=
RE: Internal Sound is working but no sound for headphones
I'm having the same problem myself. Any help out there?
"PierreDa" wrote:
> Hi there,
> Best regards
> Pierre
Old 09-22-2006   #3 (permalink)
De-install sound drivers and re-install other one from manufacturer design
for XP or Vista.
Finally works for me.
Old 09-27-2006   #4 (permalink)
=?Utf-8?B?S2h1c3NleQ==?=
I'm having the same problem, but no amount of reinstalling/uninstalling seems
to fix it.
On top of that, my integrated mic doesn't work either.
Using a HP Pavilion dv2020ca
> for XP or Vista.
Old 05-27-2008   #5 (permalink)
Vista Home Basic
Re: Internal Sound is working but no sound for headphones
[quote==?Utf-8?B?S2h1c3NleQ==?=;79215]I'm having the same problem, but no amount of reinstalling/uninstalling seems
to fix it.
> for XP or Vista.
Hi Guys
I had the exact same problem with my Acer 3680. Internal sound working fine but no sound from headphones etc and the frustrating part was that it kept saying audio devices working fine.. Now this might sound weird but.......I took to it with the vacume cleaner (you know I put the vacuum to the jack where the headphone plugs in and wallah!!! it worked not a very technical method but hey.... I don't know maybe or obviously it just had a bit of dust or dirt or something in there. Worth a try!!!
Old 05-29-2008   #6 (permalink)
Patrick Keenan
"Kobegray" <guest@xxxxxx-email.com> wrote in message
news:3cf79e0d3a0f872df2c685bfe491614b@xxxxxx-gateway.com...
Quote:
> =?Utf-8?B?S2h1c3NleQ==?=;79215 Wrote:
>> seems
>> to fix it.
>> "PierreDa" wrote:
>> design
Quote:
>> > for XP or Vista.
>> Hi Guys
>> vacuum to the jack where the headphone plugs in and wallah!!! it worked.
This actually is not a good idea. Vaccuum cleaners can build up huge
amounts of static electricity which can kill PC components.
Instead, use cans of compressed air.
HTH
-pk
Quote:
> Kobegray
Sound from headphones but not internal speakers Sound & Audio
No sound through headphones, speakers working Vista General
Internal sound is woring but no way to use headphones (no sound) Vista installation & setup
Internal Sound is working but no sound for headphones Vista installation & setup
