Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Internal Sound is working but no sound for headphones
Old 09-04-2006   #1 (permalink)
=?Utf-8?B?UGllcnJlRGE=?=
Hi there,
I use Vista Pre-RC1 and installed it without problem. Working fine right now.
I have just a problem with external sound.
As my internal sound and speakers works well, I can't have sound on my jack
where I can connect external speakers or headphones ... NO WAY !!
Any solutions will be welcom ...
Best regards
Pierre
Sound from headphones but not internal speakers Sound & Audio
Internal Sound is working but no sound for headphones Vista installation & setup
No sound through headphones, speakers working Vista General
Internal sound is woring but no way to use headphones (no sound) Vista installation & setup
