| | Internal Sound is working but no sound for headphones Hi there, I use Vista Pre-RC1 and installed it without problem. Working fine right now. I have just a problem with external sound. As my internal sound and speakers works well, I can't have sound on my jack where I can connect external speakers or headphones ... NO WAY !! Any solutions will be welcom ... Best regards Pierre |
| Sound from headphones but not internal speakers | Sound & Audio | |||
| Internal Sound is working but no sound for headphones | Vista installation & setup | |||
| No sound through headphones, speakers working | Vista General | |||
| Internal sound is woring but no way to use headphones (no sound) | Vista installation & setup | |||
