| Vista Ultimate 64bit | Vista Ultimate 64bit power(?) problem!!! Hi Need help..! I have installed vista ultimate 64bit but now vista wont boot if i have the power supply plugged in (i have a laptop)... I does boot without the power supply cabel plugged in, but vista runs very slowly and so does the internet connection. I cant install any programs, tryed to install messenger but it just freeze when it says " installing". Cant download updates from windows update, it says " downloading updates" and nothing happens. And if i plugg in the power supply after Vista booted, the battery charges for about 30 sec then it just stays in for example 50%... The battery doesnt run out of power but it doesnt charges... And when i shut down the computer it freezes at "logging out" and i have to turnt it of manually. Everything works fine in safe mode..! I should mension that when i tried to install Vista, that didnt work either with the power supply cable plugged in... just freeze just before the "choose language" meny pop up, and when i tried without the cabel i worked just fine... I have tried different ISO disks with Vista Ultimate...same problem PLEASE HELP! I had Vista home premium before and never had any problems... My hardware is... Fujitsu siemens Amilo a1667g amd 64bit +4000 1 GB RAM 80 GB HDD thanks/// Hazze |
vista ultimate 32bit and ultimate 64bit | General Discussion | |||
| Problem with Aero on Vista Ultimate 64bit | Vista General | |||
| Vista Premium 64bit to Ultimate 64bit Upgrade Fails | Vista installation & setup | |||
| Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media | Vista installation & setup | |||
| Windows Vista Ultimate 64Bit RTM :: Sound Problem | Vista hardware & devices | |||
