| | Error booting system from Vista Home Basic 64-bit DVD Hi! I currently have Vista Basic Home 32bit installed on my PC. I have the Vista Home Basic 64bit Full DVD and I would like to upgrade. I know that I would need to do a clean install but I am having trouble booting from the DVD. I have set my BIOS to boot from the DVD but I get the below message when it tries to read the DVD: File: /Boot/BCD Status: 0xc000000e Info: An error occured while attempting to read the boot configuration data. Any ideas on what the problem is? My motherboard and cpu are new and 64bit compatible. Justin |
| Re: Vista Home Premium 64 bit Upgrade from Vista Home Basic 32 bitoperating system | Vista installation & setup | |||
| Vista Home Basic 64 Bit - Trying to install - error on boot? | Drivers | |||
| Removing Vista Home Basic on a system that also has Vista Home Pre | Vista General | |||
| Desktop has disappeared (Vista home basic) system restore doesn't help. Any boffins | General Discussion | |||
| Upgrade System and Vista 64 Home Basic | General Discussion | |||
