| Guest | Vista power settings - power button functionality Just got a Vista laptop after about 4 years of XP. There is one item from XP that I was wondering whether or not could be enabled on Vista. Does anyone know if there is a tweak or fix to add to the power options (When the computer power button is pressed, do this...) the old XP "ask me what to do?" I think it is a useful piece of functionality, and I prefer it to scrounging through the start menu everytime I want to power down, hibernate, or sleep my laptop. |
| Guest | Re: Vista power settings - power button functionality Vista Power Plan Settings http://www.realtime-vista.com/admini...n_settings.htm -- Carey Frisch Microsoft MVP Windows Desktop Experience - Windows Vista Enthusiast --------------------------------------------------------------- "phase4" <phase4@xxxxxx> wrote in message news:7FF69430-0EB1-4DF3-8953-4C063185C659@xxxxxx Just got a Vista laptop after about 4 years of XP. There is one item from XP that I was wondering whether or not could be enabled on Vista. Does anyone know if there is a tweak or fix to add to the power options (When the computer power button is pressed, do this...) the old XP "ask me what to do?" I think it is a useful piece of functionality, and I prefer it to scrounging through the start menu everytime I want to power down, hibernate, or sleep my laptop. |
| Guest | Re: Vista power settings - power button functionality So there's no way to configure Vista so that it will ask me what I want to do when I push the power button? "Carey Frisch [MVP]" wrote: Quote: > Vista Power Plan Settings > http://www.realtime-vista.com/admini...n_settings.htm > > -- > Carey Frisch > Microsoft MVP > Windows Desktop Experience - > Windows Vista Enthusiast > > --------------------------------------------------------------- > > "phase4" <phase4@xxxxxx> wrote in message news:7FF69430-0EB1-4DF3-8953-4C063185C659@xxxxxx > Just got a Vista laptop after about 4 years of XP. There is one item from XP > that I was wondering whether or not could be enabled on Vista. > > Does anyone know if there is a tweak or fix to add to the power options > (When the computer power button is pressed, do this...) the old XP "ask me > what to do?" > > I think it is a useful piece of functionality, and I prefer it to scrounging > through the start menu everytime I want to power down, hibernate, or sleep my > laptop. > |
| Guest | Re: Vista power settings - power button functionality Sure. Open "Power Options" located in your Control Panel and in the left-hand pane, click on "Choose what the power buttons do". -- Carey Frisch Microsoft MVP Windows Desktop Experience - Windows Vista Enthusiast --------------------------------------------------------------- "phase4" wrote: So there's no way to configure Vista so that it will ask me what I want to do when I push the power button? "Carey Frisch [MVP]" wrote: Quote: > Vista Power Plan Settings > http://www.realtime-vista.com/admini...n_settings.htm > > -- > Carey Frisch > Microsoft MVP > Windows Desktop Experience - > Windows Vista Enthusiast > > --------------------------------------------------------------- > > "phase4" <phase4@xxxxxx> wrote in message news:7FF69430-0EB1-4DF3-8953-4C063185C659@xxxxxx > Just got a Vista laptop after about 4 years of XP. There is one item from XP > that I was wondering whether or not could be enabled on Vista. > > Does anyone know if there is a tweak or fix to add to the power options > (When the computer power button is pressed, do this...) the old XP "ask me > what to do?" > > I think it is a useful piece of functionality, and I prefer it to scrounging > through the start menu everytime I want to power down, hibernate, or sleep my > laptop. > |
| Administrator | Re: Vista power settings - power button functionality There is no way to set it to ask what you want it to do when you press the power button. You can only select what you what it to do. This tutorial will show you how to. Power Button You could use the Alt+F4 option to be able to select a shutdown option though. Shutdown Vista from the Keyboard Hope this helps, Shawn |
| Alter (auto) Power settings when plugged in or on Battery Power? | Vista performance & maintenance | |||
| Dell- blinking power button- vista power mgmt? | General Discussion | |||
| Power Button - annoyance - in Vista | Vista General | |||
| vista power button question | Vista General | |||
| power option - Power button | Vista General | |||
