Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Difference between Feb CTP & Checked/Debug
Old 04-01-2006   #1 (permalink)
TonyK
What is the difference between the Feb CTP and the Checked/Debug version that
was released last week? They both have the same build #5308.
Tony
Old 04-01-2006   #2 (permalink)
Zack Whittaker
Re: Difference between Feb CTP & Checked/Debug
I think this article explains it - unstaged and staged installations:
http://www.vistabase.co.uk/welcome.p...stagedunstaged
BTW, that article is useless to you if I'm barking up the wrong tree on this
one $
Zack Whittaker
Windows Server 2003 R2 Mentor
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: www.msblog.org
» Vista Knowledge Base: www.vistabase.co.uk
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--- Original message follows ---
"TonyK" <TonyK@discussions.microsoft.com> wrote in message
newsF7A3626-CC24-4516-AAA8-01D264E5A968@microsoft.com...
> that
> Tony
Old 04-01-2006   #3 (permalink)
Jupiter Jones [MVP]
Tony;
Unless you are a developer, you probably want to stay away from the
Checked/Debug versions.
I do not know much about them, but from what I understand, they have more
code used by developers.
But that code causes performance issues (by design), since performance is
not the intent.
Unless you need the Checked/Debug version, you have nothing to gain and
something to lose by installing that version.
This tells a little bit:
http://www.microsoft.com/whdc/DevToo...s/chkblds.mspx
Jupiter Jones [MVP]
http://www3.telus.net/dandemar
http://www.dts-l.org
> that
> Tony
Can't see checked or unchecked values Vista General
Mail disappear.have checked everything... Vista mail
one of your disks needs to be checked for consistency Vista hardware & devices
checked the sum!!... but still.... Vista installation & setup
Checked Build Vista General
