Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Disk management refuses to assign a disk letter. Help!
Old 08-13-2008   #1 (permalink)
Andy G
I have a WD MyBook external hard drive, capacity 250GB. It is a USB device
and needs no drivers, or at least it didn't when connected to my previous HP
notebook running XP.
When I connect it to my latest HP notebook (Compaq 6720s), it shows up in
Device Manager, which lists it as working properly. However, there is no
sign of it in Explorer or in Computer. When I look in Admin Tools under
Disk Management, it is shown as Disk 1, but with no drive letter. If I
select it and right click and choose "Change Drive Letter and Paths", I get
an error message saying:
"The operation failed to complete because the Disk Management console view
is not up to date. Refresh the view using the Refresh Task. If the problem
persists close the Disk Management console, then restart Disk Management, or
restart the computer."
As you will guess, neither refreshing nor restarting makes any difference.
What on earth do I do to perform this apparently simple operation?
Any help appreciated.
Andy
Old 08-13-2008   #2 (permalink)
Ramesh MVP
Re: Disk management refuses to assign a disk letter. Help!
Use DISKPART
Select the disk
SELECT DISK [ID]
*LIST partition [id]*
now select the appropirate partition
SELECT PARTITION [ID]
*ASSIGN*
Ramesh MVP
'Ramesh Kumar' (http://itsmywindows.com)
Microsoft MVP
Windows Desktop Experience
Ramesh MVP's Profile: http://winvistaclub.com/forum/member.php?userid=17
View this thread: http://winvistaclub.com/forum/showthread.php?t=19005
Old 08-14-2008   #3 (permalink)
Andy G
Trying to do what you say, but assign apparently only works on a selected
volume, (not a partition). I can list a partition for the disk in question
but I cannot list or select a volume.....
Any ideas?
"Ramesh MVP" <Ramesh.MVP.3e3pbx@xxxxxx> wrote in message
news:Ramesh.MVP.3e3pbx@xxxxxx
Quote:
> Use DISKPART
> Select the disk
> SELECT DISK [ID]
> *ASSIGN*
> Ramesh MVP
> Microsoft MVP
Old 08-15-2008   #4 (permalink)
Roberto le Cornielle
"Andy G" <georgi66@xxxxxx> wrote in message
news:e2riv4U$IHA.4156@xxxxxx
>HP notebook running XP.
> get an error message saying:
> problem persists close the Disk Management console, then restart Disk
> Management, or restart the computer."
> Andy
Have you initialized and formatted the external HDD ?.
http://www.youtube.com/watch?v=rEyvdhZemSg
rgds
Roberto
computer management-disk management problem General Discussion
Cannot change drive letter via Disk management Vista hardware & devices
Flash Drive has no drive letter... Not in Disk Management Vista hardware & devices
Disk Management > "Connecting to Virtual Disk Service" Vista hardware & devices
New 2nd Hard Disk -visible in Disk Management - but NOT in Explorer/Computer Vista hardware & devices
