Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Vista 5308 and Sound Blaster Live 24 bit install problem
Old 05-09-2006   #1 (permalink)
Jerry C. Hughes
Is there a trick to installing this hardware? I have the vista drivers but
get message of failed install .
Says something about parameter error.
Jerry
Old 05-10-2006   #2 (permalink)
Andre Da Costa [Extended64]
Re: Vista 5308 and Sound Blaster Live 24 bit install problem
The workaround is to extract the SoundBlaster 24 driver file file using
WinZip for instance. Now go to the folder where you extracted the file. Find
the Drivers folder. Now in that folder click on Support. Now click on i386
folder. In that folder you will find the ctzapxx.exe file. Double click on
the file and the drivers should install correctly. Not a very smooth install
for sure. For some reason the SB 24 drivers have been a real problem working
under Vista.
Andre
Windows Connected | http://www.windowsconnected.com
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
"Jerry C. Hughes" <jerryhughes@cox.net> wrote in message
news:uFJeM89cGHA.4428@TK2MSFTNGP03.phx.gbl...
> Jerry
Old 05-12-2006   #3 (permalink)
Jerry C. Hughes
"Andre Da Costa [Extended64]" <andred25@hotmail.com> wrote in message
news:OhvDQuEdGHA.1792@TK2MSFTNGP03.phx.gbl...
> Find the Drivers folder. Now in that folder click on Support. Now click on
> i386 folder. In that folder you will find the ctzapxx.exe file. Double
> click on the file and the drivers should install correctly. Not a very
> smooth install for sure. For some reason the SB 24 drivers have been a
> real problem working under Vista.
I can't thank you enough for your answer to my problem. I had struggled for
a week on it.
Thanks/Thanks
Jerry
Old 05-13-2006   #4 (permalink)
You are welcome Jerry.
Andre
news:uDbYdLjdGHA.1276@TK2MSFTNGP03.phx.gbl...
>> on i386 folder. In that folder you will find the ctzapxx.exe file. Double
> for a week on it.
> Thanks/Thanks
> Jerry
Old 07-07-2006   #5 (permalink)
=?Utf-8?B?VGhvcmJlbg==?=
Hey Andre,
I was wondering if you have your SB 24bit also running on Beta 2 build 5384.
I have an Sound Blaster Live! 24-bit 7.1 internal and I just cannot get it
to work under build 5384.
I followed your steps and even select the "disable driver signature" every
time during start up but nothing works.
any ideas...?
Thanks,
Thorben
> under Vista.
> Andre
> > Jerry
Drivers For Vista - Sound Blaster Live! Digital Entertainment 5.1 (SE) Vista hardware & devices
Sound Blaster Live! 24-bit Vista General
Vista & Sound Blaster Live! 5.1 Digital Player Vista General
Sound Blaster Live Vista hardware & devices
Sound Blaster Live! 24-bit Vista Beta 2 x64 Vista hardware & devices
