| | installation problem I had downloaded the 32 bit edition and tried to install after creating the boot cd .It gave an error that all files not available after installing 10% of files (error 0x800703e6). Please help me solve the problem |
| | Re: installation problem "maha" <maha@discussions.microsoft.com> wrote in message news:4D67ED2C-DA7B-498C-BDEC-67AF1C048D96@microsoft.com... >I had downloaded the 32 bit edition and tried to install after creating > the boot cd .It gave an error that all files not available after > installing 10% of files (error 0x800703e6). > > Please help me solve the problem > > Boot CD? AFAIK, you need to burn the ISO to a DVD using a feature of your burn software called something like (depending on which software you use) "Burn Image to Disk". MS recommends that the burn be done at 1x or 2x to maximize quality. |
| | Re: installation problem "pvdg42" wrote: > > "maha" <maha@discussions.microsoft.com> wrote in message > news:4D67ED2C-DA7B-498C-BDEC-67AF1C048D96@microsoft.com... > >I had downloaded the 32 bit edition and tried to install after creating > > the boot cd .It gave an error that all files not available after > > installing 10% of files (error 0x800703e6). > > > > Please help me solve the problem > > > > > Boot CD? > AFAIK, you need to burn the ISO to a DVD using a feature of your burn > software called something like (depending on which software you use) "Burn > Image to Disk". > MS recommends that the burn be done at 1x or 2x to maximize quality. > > Thanks for the help. |
| I am at my end with the installation problem | Vista installation & setup | |||
| Installation problem | General Discussion | |||
| Problem in installation! | General Discussion | |||
| installation problem | General Discussion | |||
| Installation problem | Vista installation & setup | |||
