Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista Tutorial - In Place Upgrade on non SP1 machine using SP1 DVD?
Old 09-27-2008   #1 (permalink)
Vista Home Premium 32bit
I have a Dell laptop running Vista Home Premium. Vista SP1 will not install either through WU or manually. I've tried several possible solutions, but it appears it is due to a corrupt manifest file (0 length file).
Microsoft wants me to do an in place upgrade. I requested the DVD required from Dell but the DVD they sent has SP1 included.
My question is, can I do an in place upgrade on a non-SP1 system, using the SP1 slipstreamed DVD? Or is this just asking for trouble? If it would work, I would automatically have SP1 installed.
Thanks!
Old 09-27-2008   #2 (permalink)
Ramesh Kumar MVP
Guest
Re: In Place Upgrade on non SP1 machine using SP1 DVD?
I suggest to go for clean Vista SP1 installation.
Ramesh Kumar MVP
RAMESH KUMAR
Microsoft MVP: 'My MVP Profile'
(https://mvp.support.microsoft.com/profile/Ramesh.Kumar)
My Blog: 'It's My Windows' (http://itsmywindows.com)
Ramesh Kumar MVP's Profile: http://winvistaclub.com/forum/member.php?userid=17
View this thread: http://winvistaclub.com/forum/showthread.php?t=23028
Old 09-28-2008   #3 (permalink)
CH
Guest
Hi mikej--
Good for Dell for keeping their word that they would ship an actual Vista
DVD with their boxes, because there is no comparision in the help you can
get from one vs. the often worthless "recovery CDs with XP and recovery DVDs
with Vista" that the OEMs get away with shipping.
What Dell ***promised*** on their blog around the time Vista RTM'd was that
they were going to ship a Vista DVD with each and every box.
With a Vista DVD you have the advantage of doing a startup repair, a repair
install, or using what will fix a wide range of software caused no boot
Vistas, the bootrec.exe command switches that aren't well known but will
often fix a no boot Vista when other methods won't.
You're question's a good one. My experience is that when I've repaired no
boot's with a DVD that is earlier than the OS service packquite a few times
in XP, specifically XP SP2 boxes with an XP SP1 or XP CD, that the repaired
OS became whatever the CD's service pack level was that I used to repair.
Your situation is that you want to run a repair install with the
slipstreamed SP1 on a Vista HP RTM. I can't imagine any reason whatsoever
that you're going to have any trouble at all doing this. I would expect
that to get you Vista SP1 on your box. Vista SP1 is Vista RTM + the SP1
files.
Back up of course, but I'd go for it.
Good luck,
CH
"mikej" <guest@xxxxxx-email.com> wrote in message
news:7e36f479bb7cbdfe42a374f5be2d040f@xxxxxx-gateway.com...
> file).
> Thanks!
> mikej
Old 09-30-2008   #4 (permalink)
Darrell Gorter[MSFT]
Guest
Hello,
Sorry not going to work.
whatsoever
| >files.
The upgrade path from RTM installation to Integrated (slipstreamed) SP1
media is not available.
Thanks,
This posting is provided "AS IS" with no warranties, and confers no rights
| >From: "CH" <windows7@xxxxxx>
| >References: <7e36f479bb7cbdfe42a374f5be2d040f@xxxxxx-gateway.com>
| >In-Reply-To: <7e36f479bb7cbdfe42a374f5be2d040f@xxxxxx-gateway.com>
| >Subject: Re: In Place Upgrade on non SP1 machine using SP1 DVD?
| >Date: Sun, 28 Sep 2008 19:09:47 -0400
| >Lines: 51
| >MIME-Version: 1.0
| >Content-Type: text/plain;
| > format=flowed;
| > charset="iso-8859-1";
| > reply-type=original
| >Content-Transfer-Encoding: 7bit
| >X-Priority: 3
| >X-MSMail-Priority: Normal
| >X-Newsreader: Microsoft Windows Mail 6.0.6001.18000
| >X-MimeOLE: Produced By Microsoft MimeOLE V6.0.6001.18049
| >Message-ID: <#1i4R9bIJHA.1968@xxxxxx>
| >Newsgroups: microsoft.public.windows.vista.installation_setup
| >NNTP-Posting-Host: c-24-98-46-50.hsd1.ga.comcast.net 24.98.46.50
| >Path: TK2MSFTNGHUB02.phx.gbl!TK2MSFTNGP01.phx.gbl!TK2MSFTNGP06.phx.gbl
| >Xref: TK2MSFTNGHUB02.phx.gbl
microsoft.public.windows.vista.installation_setup:45502
| >X-Tomcat-NG: microsoft.public.windows.vista.installation_setup
| >Hi mikej--
Vista
can
DVDs
that
repair
no
times
repaired
repair.
whatsoever
| >files.
| >Good luck,
| >CH
length
| >> file).
| >> Thanks!
| >> mikej
Old 10-01-2008   #5 (permalink)
Hello Darrell, can you briefly explain why it wouldn't work? I'm just curious. Thanks.
Old 10-03-2008   #6 (permalink)
Guest
Hello Mike,
That scenario is blocked by setup, so running setup would fail with an
error message telling you that you need to install SP1 before you can
upgrade.
Thanks,
| >From: mikej <guest@xxxxxx-email.com>
| >Date: Wed, 1 Oct 2008 15:42:21 -0500
| >Message-ID: <0d2c5c89133d4cb53907d3aaee9a843a@xxxxxx-gateway.com>
| >Organization: Forums
| >User-Agent: vBulletin USENET gateway
| >X-Newsreader: vBulletin USENET gateway
| >X-Originating-IP: 209.159.64.4
| >NNTP-Posting-Host: vistax64.com 74.86.192.138
| >Lines: 1
| >Path: TK2MSFTNGHUB02.phx.gbl!TK2MSFTNGP01.phx.gbl!TK2MSFTNGP02.phx.gbl
microsoft.public.windows.vista.installation_setup:45591
curious. Thanks.
mikej
In place upgrade help General Discussion
in-place upgrade - new registry or not??? Vista installation & setup
In-Place upgrade x32 to x64? Vista installation & setup
In-Place Upgrade Vista installation & setup
32 Bit XP Pro In-Place Upgrade to 64 Bit Vista Vista installation & setup
