Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Lost XP Boot and Vista Pro Boot will not work on my system
Old 09-20-2006   #1 (permalink)
=?Utf-8?B?VG9tIFo=?=
had everything working fine, then ran vista pro boot and got all kinds of
errors when I started it up and now I cannot boot into XP
Old 09-20-2006   #2 (permalink)
Mark D. VandenBerg
Re: Lost XP Boot and Vista Pro Boot will not work on my system
What changes did you make with VBP? Will undoing the changes you made not
work? If everything was "working fine" why did you feel the need to edit
the boot files?
"Tom Z" <Tom Z@discussions.microsoft.com> wrote in message
news:79C8E892-A306-43DB-8FF9-1597A1C03F82@microsoft.com...
Old 09-20-2006   #3 (permalink)
VBR?... i'm not that smart... I wanted to change the default op system so I
ran the 2.1 version on vista pro boot. I had previously ran 1.0, but had the
same issues with bad index counts... I can only get XP back by uninstalling
vista pro boot
> the boot files?
Old 09-23-2006   #4 (permalink)
John Barnes
So what is your problem if you uninstall VistaBootPro and everything works
fine, leave it uninstalled and try EasyBCD and see if that one will work for
you.
"Tom Z" <TomZ@discussions.microsoft.com> wrote in message
news:0B138F67-863B-4487-AA1D-9A57CEB56771@microsoft.com...
> I
> the
> uninstalling
> vista pro boot
>> not
>> the boot files?
>> > of
Dual boot [Vista C] lost Ntldr recovrd fcd lost DB Vista installation & setup
vista triple boot, will it work like dual boot? General Discussion
NICs fail to work on every boot and system slows to a freeze Vista networking & sharing
system restore wont work/cant boot into safe mode (vista home) Vista General
dual boot but lost vista boot loader Vista installation & setup
