| | 0X0000005C eeeerrrrrrr this makes my head hurt,help. Hi all, I hope someone can help me or point me in the right direction. When i try to install vista from disc i get an (ERROR) the error is STOP 0X0000005C) 0X0000010B 0X00000003 0X00000000 0X00000000this happens when i first put the disc in and loads the first set of files then i get a blue screen with the above. this also happens when i upgrade xp to vista... any ideas....... microsoft windows xp media center edition version 2002 service pack2 hp pavilion intel® pentium® 4cpu 3.00ghz 3.00ghz 1.00gb of ram |
| | Re: 0X0000005C eeeerrrrrrr this makes my head hurt,help. Did you burn the ISO to a DVD, if so try burning it again at a lower burn speed such as 1X. This has been an issue for some throughout the beta and MS has suggested burning at lower speeds and it has helped some folks. Eddie Johnson "del69" <del69@discussions.microsoft.com> wrote in message news:12A03BB2-4D93-46E5-A8E4-302413094A5D@microsoft.com... > Hi all, > > > I hope someone can help me or point me in the right direction. > > > When i try to install vista from disc i get an (ERROR) > > the error is STOP 0X0000005C) 0X0000010B 0X00000003 0X00000000 0X00000000> > this happens when i first put the disc in and loads the first set of files > then i get a blue screen with the above. > > this also happens when i upgrade xp to vista... > > any ideas....... > > microsoft windows xp > media center edition > version 2002 > service pack2 > > hp pavilion > intel® > pentium® 4cpu 3.00ghz 3.00ghz > 1.00gb of ram |
| | Re: 0X0000005C eeeerrrrrrr this makes my head hurt,help. thanx ive just tried it at a low burn rate but still i get the same stop error. any more ideas?? "Eddie Johnson" wrote: > Did you burn the ISO to a DVD, if so try burning it again at a lower burn > speed such as 1X. This has been an issue for some throughout the beta and MS > has suggested burning at lower speeds and it has helped some folks. > > Eddie Johnson > > "del69" <del69@discussions.microsoft.com> wrote in message > news:12A03BB2-4D93-46E5-A8E4-302413094A5D@microsoft.com... > > Hi all, > > > > > > I hope someone can help me or point me in the right direction. > > > > > > When i try to install vista from disc i get an (ERROR) > > > > the error is STOP 0X0000005C) 0X0000010B 0X00000003 0X00000000 0X00000000> > > > this happens when i first put the disc in and loads the first set of files > > then i get a blue screen with the above. > > > > this also happens when i upgrade xp to vista... > > > > any ideas....... > > > > microsoft windows xp > > media center edition > > version 2002 > > service pack2 > > > > hp pavilion > > intel® > > pentium® 4cpu 3.00ghz 3.00ghz > > 1.00gb of ram > > |
| | Re: 0X0000005C eeeerrrrrrr this makes my head hurt,help. Did you check the hashes of the ISO you downloaded? -- Tom Ziegmann Microsoft Certified Professional Windows Vista / Server Longhorn TechBeta Tester Windows Server 2003 SP2 TechBeta Tester "del69" <del69@discussions.microsoft.com> wrote in message news:616E633D-F523-4DA3-AEB0-F4740F9DED9A@microsoft.com... > thanx ive just tried it at a low burn rate but still i get the same stop > error. any more ideas?? > > "Eddie Johnson" wrote: > >> Did you burn the ISO to a DVD, if so try burning it again at a lower burn >> speed such as 1X. This has been an issue for some throughout the beta and >> MS >> has suggested burning at lower speeds and it has helped some folks. >> >> Eddie Johnson >> >> "del69" <del69@discussions.microsoft.com> wrote in message >> news:12A03BB2-4D93-46E5-A8E4-302413094A5D@microsoft.com... >> > Hi all, >> > >> > >> > I hope someone can help me or point me in the right direction. >> > >> > >> > When i try to install vista from disc i get an (ERROR) >> > >> > the error is STOP 0X0000005C) 0X0000010B 0X00000003 0X00000000>> > 0X00000000 >> > >> > this happens when i first put the disc in and loads the first set of >> > files >> > then i get a blue screen with the above. >> > >> > this also happens when i upgrade xp to vista... >> > >> > any ideas....... >> > >> > microsoft windows xp >> > media center edition >> > version 2002 >> > service pack2 >> > >> > hp pavilion >> > intel® >> > pentium® 4cpu 3.00ghz 3.00ghz >> > 1.00gb of ram >> >> |
| | Re: 0X0000005C eeeerrrrrrr this makes my head hurt,help. hhmmm no i did't check????????????? "Tom Ziegmann" wrote: > Did you check the hashes of the ISO you downloaded? > > -- > Tom Ziegmann > Microsoft Certified Professional > Windows Vista / Server Longhorn TechBeta Tester > Windows Server 2003 SP2 TechBeta Tester > "del69" <del69@discussions.microsoft.com> wrote in message > news:616E633D-F523-4DA3-AEB0-F4740F9DED9A@microsoft.com... > > thanx ive just tried it at a low burn rate but still i get the same stop > > error. any more ideas?? > > > > "Eddie Johnson" wrote: > > > >> Did you burn the ISO to a DVD, if so try burning it again at a lower burn > >> speed such as 1X. This has been an issue for some throughout the beta and > >> MS > >> has suggested burning at lower speeds and it has helped some folks. > >> > >> Eddie Johnson > >> > >> "del69" <del69@discussions.microsoft.com> wrote in message > >> news:12A03BB2-4D93-46E5-A8E4-302413094A5D@microsoft.com... > >> > Hi all, > >> > > >> > > >> > I hope someone can help me or point me in the right direction. > >> > > >> > > >> > When i try to install vista from disc i get an (ERROR) > >> > > >> > the error is STOP 0X0000005C) 0X0000010B 0X00000003 0X00000000> >> > 0X00000000 > >> > > >> > this happens when i first put the disc in and loads the first set of > >> > files > >> > then i get a blue screen with the above. > >> > > >> > this also happens when i upgrade xp to vista... > >> > > >> > any ideas....... > >> > > >> > microsoft windows xp > >> > media center edition > >> > version 2002 > >> > service pack2 > >> > > >> > hp pavilion > >> > intel® > >> > pentium® 4cpu 3.00ghz 3.00ghz > >> > 1.00gb of ram > >> > >> > |
| | #6 (permalink) |
| | Re: 0X0000005C eeeerrrrrrr this makes my head hurt,help. Don't mean to sound all defeatest and all, but it looks like you got a crapped download. "del69" wrote: > hhmmm no i did't check????????????? > > "Tom Ziegmann" wrote: > > > Did you check the hashes of the ISO you downloaded? > > > > -- > > Tom Ziegmann > > Microsoft Certified Professional > > Windows Vista / Server Longhorn TechBeta Tester > > Windows Server 2003 SP2 TechBeta Tester > > "del69" <del69@discussions.microsoft.com> wrote in message > > news:616E633D-F523-4DA3-AEB0-F4740F9DED9A@microsoft.com... > > > thanx ive just tried it at a low burn rate but still i get the same stop > > > error. any more ideas?? > > > > > > "Eddie Johnson" wrote: > > > > > >> Did you burn the ISO to a DVD, if so try burning it again at a lower burn > > >> speed such as 1X. This has been an issue for some throughout the beta and > > >> MS > > >> has suggested burning at lower speeds and it has helped some folks. > > >> > > >> Eddie Johnson > > >> > > >> "del69" <del69@discussions.microsoft.com> wrote in message > > >> news:12A03BB2-4D93-46E5-A8E4-302413094A5D@microsoft.com... > > >> > Hi all, > > >> > > > >> > > > >> > I hope someone can help me or point me in the right direction. > > >> > > > >> > > > >> > When i try to install vista from disc i get an (ERROR) > > >> > > > >> > the error is STOP 0X0000005C) 0X0000010B 0X00000003 0X00000000> > >> > 0X00000000 > > >> > > > >> > this happens when i first put the disc in and loads the first set of > > >> > files > > >> > then i get a blue screen with the above. > > >> > > > >> > this also happens when i upgrade xp to vista... > > >> > > > >> > any ideas....... > > >> > > > >> > microsoft windows xp > > >> > media center edition > > >> > version 2002 > > >> > service pack2 > > >> > > > >> > hp pavilion > > >> > intel® > > >> > pentium® 4cpu 3.00ghz 3.00ghz > > >> > 1.00gb of ram > > >> > > >> > > |
| | #7 (permalink) |
| Vista Ultimate w/SP1 (32-bit) and Windows 7 Build 7000 (64-bit) | I had the same problem on my HP Pavilion a1320n PC, all I did was update the BIOS and it worked, go here: http://www.hp.com/country/us/en/support.html?cc=ca and fill in your PC type (Example, Pavilion a1320n) and then download the latest BIOS update. |
| I doubt you can help but doesn't hurt to ask | Network & Sharing | |||
| Will this hurt my laptop? | Vista General | |||
| a world of hurt (vista is dumped on me) | Vista General | |||
| For every 1 dollar MS makes the rest of the world makes 18... | Vista General | |||
