Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Dual Boot Vista Ultimate and Xp Home Problem...Please Help
Old 12-16-2008   #1 (permalink)
window vista
Hello Board !
System Info:
Windows Vista Ultimate SP3
Intel(R) Pentium(R) Dual CPU T2370 @1.73GHz 1.73 GHz.
Memory (RAM) 1.00 GB.
32-bit OS.
My Original OS is Vista Ultimate SP3. I tried to dual boot with XP Home SP3. The Xp installation process went smoothly. All the program files and system files are there(so I thought). The Vista is in C: drive and the XP is in E: drive, which I have created and formatted. Here comes the problem. I CAN NOT BOOT FROM THE XP Home Edition although at the booting screen, it allows me the OS booting option which are Windows Vista Ultimate and XP Home SP3. Vista boots with ease but the XP on the other hand, refuses to do so. The booting window pops up and begins the process but instantly shuts down and follows with this error at the Windows Boot Manager:
File: \NTLDR
Status: 0x000000f
Info: The selected entry could not be loaded because the application is missing or corrupt.
Fine. These are the steps I took trying to solve this error.
  1. Copied the NTLDR and the NTDETECT files from the Vista root drive(C:\ntldr/NTDETECT) to XP root drive(E:\ntldr/NTDETECT).
  2. Used the EasyBCD 1.7.2 application to add new entry(XP) at the booting.
Unfortunately, it did not solve this problem. I have no choice but to run Vista as of now . However, when I open up msconfig. Under the BOOT tab, there is only one OS available and that is the all mighty Vista. No XP. How can I add the installed XP OS to the list?
Also, where can I locate the boot.ini file on my computer? it was suggested on the other forum that these three files(ntldr, ntdetect, and boot.ini) should be in the same root drives of both Vista & XP. Mind you, I have all the hidden system files opened. Can someone please help me out on how to boot from the XP OS?
Thanks for any help or input.
Old 12-16-2008   #2 (permalink)
peter
Re: Dual Boot Vista Ultimate and Xp Home Problem...Please Help
1st Vista is only on SP1...SP2 is in BETA...and SP3 is a gleam in some
programmers eye.
Use your Vista CD and do a start up repair.
peter
If you find a posting or message from me offensive,inappropriate
or disruptive,please ignore it.
If you dont know how to ignore a posting complain
to me and I will be only too happy to demonstrate :-)
"bennys" <guest@xxxxxx-email.com> wrote in message
news:19bd8c9e0da3358aa61dfdb1d0cf7240@xxxxxx-gateway.com...
Quote:
> Hello Board !
> System Info:
> 32-bit OS.
> My Oiginal OS is Vista Ultimate SP3. I tried to dual boot with XP Home
> -FILE: \NTLDR
> STATUS: 0X000000F
> INFO: THE SELECTED ENTRY COULD NOT BE LOADED BECAUSE THE APPLICATION IS
> MISSING OR CORRUPT.-
> - Copied the NTLDR and the NTDETECT files from the Vista root
> - Used the EasyBCD 1.7.2 application to add new entry(XP) at the
> booting.
> bennys
Old 12-16-2008   #3 (permalink)
window vista
My apology. I meant SP1 instead of SP3.
Old 12-16-2008   #4 (permalink)
peter
no problem
try the startup repair
pk
news:37d7879ad5ad489e3aeb4d5cbd1110cb@xxxxxx-gateway.com...
> bennys
Old 12-17-2008   #5 (permalink)
Alex T.
Fixing the Vista boot loader will not fix his issue. It is with XP not with
Vista.
Benny you should read teh Wiki over at NeoSmart Technologies. The Makers of
EasyBCD.
http://neosmart.net/wiki/display/EBC...ing+Windows+XP
That page will give you all the information you need on how to fix the XP
not botting issue. If you copied over those files did you remember the
boot.ini file as well? Did you remember to check that which drive was the
boot drive so that the boot.ini info would be correct?
~Alex T.~
~A.K.A. Makaveli213~
~Windows Desktop Experience MVP~
"peter" <peter@xxxxxx> wrote in message
news:OojzdL7XJHA.5108@xxxxxx
> programmers eye.
> peter
Quote:
>> Hello Board !
>> System Info:
>> 32-bit OS.
>> -FILE: \NTLDR
>> STATUS: 0X000000F
>> booting.
>> bennys
Old 12-17-2008   #6 (permalink)
John Barnett MVP
Take a look at this article from my website:
http://vistasupport.mvps.org/install...ning_vista.htm
John Barnett MVP
Windows XP Associate Expert
Web: http://xphelpandsupport.mvps.org
Web: http://vistasupport.mvps.org
Web: http://www.silversurfer-guide.com
The information in this mail/post is supplied "as is". No warranty of any
kind, either expressed or implied, is made in relation to the accuracy,
reliability or content of this mail/post. The Author shall not be liable for
any direct, indirect, incidental or consequential damages arising out of the
use of, or inability to use, information or opinions expressed in this
mail/post..
Quote:
> Hello Board !
> System Info:
> 32-bit OS.
> -FILE: \NTLDR
> STATUS: 0X000000F
> booting.
> bennys
Old 12-21-2008   #7 (permalink)
window vista
Thank you for all the informative replies. I have fixed the problem with your help. I can now boot into both OS's.
Once again, thanks.
Dual Boot Vista Home Premium and Vista Ultimate? General Discussion
Boot Manager issue: dual boot vista 64 ultimate / windows 7 ultimate Vista installation & setup
Dual Boot VIsta Ultimate and XP Home Vista installation & setup
dual boot-vista ultimate 64/ home basic 32? General Discussion
Dual Boot XP Home & Vista Home Premium Upgrade Vista installation & setup
