| | Why give error codes if they don't help find the problem? I just cannot get RC1 to get past the Expanding files portion of the installation. I get the error code: 0x800706F8, which I have posted and asked for suggestions on, and I can't get anyone to say that error code equals this. Fix this, and the install will work. Isn't that what error codes are for? I have tried everything that I can think of and there has been no change in the installation. Does anyone have any suggestions? Please let me know if you do. Also, if I can copy the DVD to the hard drive and load it from there, please tell me how. Thanks |
| error codes | Vista General | |||
| NEED HELP WITH ERROR CODES | Vista General | |||
| Error Codes | Vista General | |||
| error codes | Vista music pictures video | |||
| WMP Error Codes | Vista General | |||
