| | Build 5728 problems I run an nforce4 SLI motherboard with 2 pairs of drives in RAID1. Beta 2 installed and ran fine. RC1 build 5600 would not even attempt to install because it couldn't find the drives. Build 5728 installs and runs once. It then tries to install some "drivers from preconfigured folders" (which fails), then a couple updates, then attempts to shut down, which hangs indefinitely. When I force a reboot, it looks like it's starting up, then goes to a black screen and never comes out of it. I have tried reinstalling twice with the same results. Has anyone else experienced this? larry |
| | Installation problem in Vista me too hv the same problem My system config : AMD 64bit 2800+ processor Asus mother board KV8-MX (VIA Chipset) 128Mb 5200 Nvidia man, 80 GB SATA HDD,512 MB RAM Vista Upgrade Advisor--> which tells my system is Compatable of installing Vista Problem : Problem arrise, when the system restarts at the time of installation, i can see the vista logo part after that no further action,I made my system even to run more then a hrs,but no other change my monitor LED is glowing.... i tried New installtion,Upgrade installtion & even booted from DVD, i cant able to proced after the Vista logo part can any one Sort out my problem Did Via chipset compatable for Vista installation "Larry Schuldt" wrote: > I run an nforce4 SLI motherboard with 2 pairs of drives in RAID1. Beta > 2 installed and ran fine. RC1 build 5600 would not even attempt to > install because it couldn't find the drives. > > Build 5728 installs and runs once. It then tries to install some > "drivers from preconfigured folders" (which fails), then a couple > updates, then attempts to shut down, which hangs indefinitely. > When I force a reboot, it looks like it's starting up, then goes to a > black screen and never comes out of it. I have tried reinstalling > twice with the same results. > > Has anyone else experienced this? > > larry > |
| | RE: Installation problem in Vista I had a problem with 5728 continuously rebooting. Used the F8 key and selected the ignore automatic reboot on hardware failure. This way you may be able to get into the shell to troubleshoot. Jonty "DeenA" wrote: > me too hv the same problem > > My system config : > AMD 64bit 2800+ processor > Asus mother board KV8-MX (VIA Chipset) > 128Mb 5200 Nvidia man, > 80 GB SATA HDD,512 MB RAM > > > Vista Upgrade Advisor--> which tells my system is Compatable of installing > Vista > > Problem : > > Problem arrise, when the system restarts at the time of installation, i can > see the vista logo part after that no further action,I made my system even to > run more then a hrs,but no other change my monitor LED is glowing.... > > i tried New installtion,Upgrade installtion & even booted from DVD, i cant > able to proced after the Vista logo part > > can any one Sort out my problem > > Did Via chipset compatable for Vista installation > > > > "Larry Schuldt" wrote: > > > I run an nforce4 SLI motherboard with 2 pairs of drives in RAID1. Beta > > 2 installed and ran fine. RC1 build 5600 would not even attempt to > > install because it couldn't find the drives. > > > > Build 5728 installs and runs once. It then tries to install some > > "drivers from preconfigured folders" (which fails), then a couple > > updates, then attempts to shut down, which hangs indefinitely. > > When I force a reboot, it looks like it's starting up, then goes to a > > black screen and never comes out of it. I have tried reinstalling > > twice with the same results. > > > > Has anyone else experienced this? > > > > larry > > |
| | Re: Build 5728 problems It's not you. I have the same problem. Microsoft has a lot of work to do for the install to work correctly with NVIDIA raid based PCs. I've heard that build 5731 seems to work but can't find a download for it so I can try it myself. "Larry Schuldt" <lschuldt@nibs.rude.biz> wrote in message news:n2duh29vqjur5qrsmddnnqm8hj2331afre@4ax.com... >I run an nforce4 SLI motherboard with 2 pairs of drives in RAID1. Beta > 2 installed and ran fine. RC1 build 5600 would not even attempt to > install because it couldn't find the drives. > > Build 5728 installs and runs once. It then tries to install some > "drivers from preconfigured folders" (which fails), then a couple > updates, then attempts to shut down, which hangs indefinitely. > When I force a reboot, it looks like it's starting up, then goes to a > black screen and never comes out of it. I have tried reinstalling > twice with the same results. > > Has anyone else experienced this? > > larry |
| | #6 (permalink) |
| | Re: Build 5728 problems i have the same problem too... I have an nForce4 RAID 0 with 4 Seagate disks and I get thru the copy and reboot stage on build 5600, but after that I'll see a pretty walpaper design and an hourglass on my screen for 7 hours before I decide to pull the plug on the operation. I figured I could leave it that way for 2 weeks and the results would be the same. Build 5728 won't even copy; I get an error code. At least it's right away and let's me know what's going on instead of just sitting idle until I decide to hit the restart button so i can have my computer back. It's definitely not seeing the RAID after bootup. I am installing the drivers from the ASUS website since I am using the A8N-SLI mobo. Any suggestions, leave them. Otherwise I'll wait until vista goes retail. chris -- Those willing to sacrifice freedom for safety are deprived both freedom and safety... "b" wrote: > It's not you. I have the same problem. Microsoft has a lot of work to do for > the install to work correctly with NVIDIA raid based PCs. I've heard that > build 5731 seems to work but can't find a download for it so I can try it > myself. > "Larry Schuldt" <lschuldt@nibs.rude.biz> wrote in message > news:n2duh29vqjur5qrsmddnnqm8hj2331afre@4ax.com... > >I run an nforce4 SLI motherboard with 2 pairs of drives in RAID1. Beta > > 2 installed and ran fine. RC1 build 5600 would not even attempt to > > install because it couldn't find the drives. > > > > Build 5728 installs and runs once. It then tries to install some > > "drivers from preconfigured folders" (which fails), then a couple > > updates, then attempts to shut down, which hangs indefinitely. > > When I force a reboot, it looks like it's starting up, then goes to a > > black screen and never comes out of it. I have tried reinstalling > > twice with the same results. > > > > Has anyone else experienced this? > > > > larry > > > |
| | #7 (permalink) |
| | Re: Build 5728 problems Aymincendiary: In beta 2 and PRC1 the Nvidia drivers installed during the add drivers mode worked. In RC1 (5600) the Nvidia raid drivers were corrupt and wouldn't install, I wiped out a raid1 array trying to install the drivers. With RC1 (5728) the Nvidia drivers are included and don't have to be added. I'm currently running Nvidia raid1 on RC1 (5728) in x64 and x86 versions. "Aymincendiary" <zbar2005@yahoo.com> wrote in message news:2B825636-81AB-4EC9-8096-20BCE3104558@microsoft.com... >i have the same problem too... I have an nForce4 RAID 0 with 4 Seagate >disks > and I get thru the copy and reboot stage on build 5600, but after that > I'll > see a pretty walpaper design and an hourglass on my screen for 7 hours > before > I decide to pull the plug on the operation. > > I figured I could leave it that way for 2 weeks and the results would be > the > same. > > Build 5728 won't even copy; I get an error code. At least it's right away > and let's me know what's going on instead of just sitting idle until I > decide > to hit the restart button so i can have my computer back. > > It's definitely not seeing the RAID after bootup. I am installing the > drivers from the ASUS website since I am using the A8N-SLI mobo. > > Any suggestions, leave them. Otherwise I'll wait until vista goes retail. > > chris > -- > Those willing to sacrifice freedom for safety are deprived both freedom > and > safety... > > > "b" wrote: > >> It's not you. I have the same problem. Microsoft has a lot of work to do >> for >> the install to work correctly with NVIDIA raid based PCs. I've heard that >> build 5731 seems to work but can't find a download for it so I can try it >> myself. >> "Larry Schuldt" <lschuldt@nibs.rude.biz> wrote in message >> news:n2duh29vqjur5qrsmddnnqm8hj2331afre@4ax.com... >> >I run an nforce4 SLI motherboard with 2 pairs of drives in RAID1. Beta >> > 2 installed and ran fine. RC1 build 5600 would not even attempt to >> > install because it couldn't find the drives. >> > >> > Build 5728 installs and runs once. It then tries to install some >> > "drivers from preconfigured folders" (which fails), then a couple >> > updates, then attempts to shut down, which hangs indefinitely. >> > When I force a reboot, it looks like it's starting up, then goes to a >> > black screen and never comes out of it. I have tried reinstalling >> > twice with the same results. >> > >> > Has anyone else experienced this? >> > >> > larry >> >> >> |
| | #8 (permalink) |
| | Re: Build 5728 problems I downloaded the vista32beta2 drivers and have gotten to where vista rc1 5600 is expanding the files on one of the partitions on my nvidia nforce4 sata raid array... so far it has been at 27% for the last 90 minutes. I noticed the screen resolution has changed and is much lower than my 1280 by 1024 set by my ATI graphics adapter. 5728 doesn't even copy the files... it stops with an error code. at least it doesn't leave me hanging for hours like 5600. i'll let it go for another 2 hours before i hit the reset button and try something else. This operating system is turning out to be a real abortion... remember windows 95 when it first came out? looks like i'll be staying with xp pro for the forseeable future. -- Those willing to sacrifice freedom for safety are deprived both freedom and safety... "Dennis Pack" wrote: > Aymincendiary: > In beta 2 and PRC1 the Nvidia drivers installed during the > add drivers mode worked. In RC1 (5600) the Nvidia raid drivers were corrupt > and wouldn't install, I wiped out a raid1 array trying to install the > drivers. With RC1 (5728) the Nvidia drivers are included and don't have to > be added. I'm currently running Nvidia raid1 on RC1 (5728) in x64 and x86 > versions. > "Aymincendiary" <zbar2005@yahoo.com> wrote in message > news:2B825636-81AB-4EC9-8096-20BCE3104558@microsoft.com... > >i have the same problem too... I have an nForce4 RAID 0 with 4 Seagate > >disks > > and I get thru the copy and reboot stage on build 5600, but after that > > I'll > > see a pretty walpaper design and an hourglass on my screen for 7 hours > > before > > I decide to pull the plug on the operation. > > > > I figured I could leave it that way for 2 weeks and the results would be > > the > > same. > > > > Build 5728 won't even copy; I get an error code. At least it's right away > > and let's me know what's going on instead of just sitting idle until I > > decide > > to hit the restart button so i can have my computer back. > > > > It's definitely not seeing the RAID after bootup. I am installing the > > drivers from the ASUS website since I am using the A8N-SLI mobo. > > > > Any suggestions, leave them. Otherwise I'll wait until vista goes retail. > > > > chris > > -- > > Those willing to sacrifice freedom for safety are deprived both freedom > > and > > safety... > > > > > > "b" wrote: > > > >> It's not you. I have the same problem. Microsoft has a lot of work to do > >> for > >> the install to work correctly with NVIDIA raid based PCs. I've heard that > >> build 5731 seems to work but can't find a download for it so I can try it > >> myself. > >> "Larry Schuldt" <lschuldt@nibs.rude.biz> wrote in message > >> news:n2duh29vqjur5qrsmddnnqm8hj2331afre@4ax.com... > >> >I run an nforce4 SLI motherboard with 2 pairs of drives in RAID1. Beta > >> > 2 installed and ran fine. RC1 build 5600 would not even attempt to > >> > install because it couldn't find the drives. > >> > > >> > Build 5728 installs and runs once. It then tries to install some > >> > "drivers from preconfigured folders" (which fails), then a couple > >> > updates, then attempts to shut down, which hangs indefinitely. > >> > When I force a reboot, it looks like it's starting up, then goes to a > >> > black screen and never comes out of it. I have tried reinstalling > >> > twice with the same results. > >> > > >> > Has anyone else experienced this? > >> > > >> > larry > >> > >> > >> > > |
| | #9 (permalink) |
| | Re: Build 5728 problems using 5600 build and the vista32beta2 sata drivers i have gotten to the expanding files portion after reboot... it has been 2 hours and is stuck at 27% this is turning out to be another win 95... -- Those willing to sacrifice freedom for safety are deprived both freedom and safety... "Aymincendiary" wrote: > i have the same problem too... I have an nForce4 RAID 0 with 4 Seagate disks > and I get thru the copy and reboot stage on build 5600, but after that I'll > see a pretty walpaper design and an hourglass on my screen for 7 hours before > I decide to pull the plug on the operation. > > I figured I could leave it that way for 2 weeks and the results would be the > same. > > Build 5728 won't even copy; I get an error code. At least it's right away > and let's me know what's going on instead of just sitting idle until I decide > to hit the restart button so i can have my computer back. > > It's definitely not seeing the RAID after bootup. I am installing the > drivers from the ASUS website since I am using the A8N-SLI mobo. > > Any suggestions, leave them. Otherwise I'll wait until vista goes retail. > > chris > -- > Those willing to sacrifice freedom for safety are deprived both freedom and > safety... > > > "b" wrote: > > > It's not you. I have the same problem. Microsoft has a lot of work to do for > > the install to work correctly with NVIDIA raid based PCs. I've heard that > > build 5731 seems to work but can't find a download for it so I can try it > > myself. > > "Larry Schuldt" <lschuldt@nibs.rude.biz> wrote in message > > news:n2duh29vqjur5qrsmddnnqm8hj2331afre@4ax.com... > > >I run an nforce4 SLI motherboard with 2 pairs of drives in RAID1. Beta > > > 2 installed and ran fine. RC1 build 5600 would not even attempt to > > > install because it couldn't find the drives. > > > > > > Build 5728 installs and runs once. It then tries to install some > > > "drivers from preconfigured folders" (which fails), then a couple > > > updates, then attempts to shut down, which hangs indefinitely. > > > When I force a reboot, it looks like it's starting up, then goes to a > > > black screen and never comes out of it. I have tried reinstalling > > > twice with the same results. > > > > > > Has anyone else experienced this? > > > > > > larry > > > > > > |
| How To Get Build 5728 x64 | Vista installation & setup | |||
| RC-1 Build 5728 | Vista General | |||
| build 5728 | Vista General | |||
| Build 5728 .. | Vista General | |||
