| Vista Ultimate 64bit | Help installing 32-bit XP PRO on existing 64-bit Vista Ultimate Hi Everyone, Wishing all a happy new year... I have HP Pavilion dv9205TX laptop with the following configuration: 64-bit core2duo 2GHz processor, 2G RAM, 2X160G HDD, 64-bit Vista Ultimate on the 1st hard drive (C: ) I want to install 32-bit Win XP PRO SP3 on the 2nd hard drive (D: ) I wanted to know if this is a straight forward installation by choosing the drive letter D: during the installation or do I still need to use the software like EasyBCD or VistaBootPro? Which of these softwares will make my work easy? Will it be easy to format the hard drive, install 32-bit XP on the 2nd hard drive(D: ) and then proceed with installing 64-bit vista on the 1st hard drive(C: ) (or) the other way around? Thank you in advance for your valuable input. I wish you all a great year ahead!! Cheers, Mahesh Last edited by mahesh_australia; 01-08-2009 at 01:13 AM.. Reason: Updated the listing for more precise info |
| VISTA HOME PREMIUM X64/ 7 x64 / 7x86 | Re: Help installing 32-bit XP PRO on existing 64-bit Vista Ultimate Hi Everyone, Wishing all a happy new year... I have HP Pavilion dv9205TX laptop with the following configuration: 64-bit core2duo 2GHz processor, 2G RAM, 2X160G HDD, 64-bit Vista Ultimate on the 1st hard drive (C: ) I want to install 32-bit Win XP PRO SP3 on the 2nd hard drive (D: ) I wanted to know if this is a straight forward installation by choosing the drive letter D: during the installation or do I still need to use the software like EasyBCD or VistaBootPro? Which of these softwares will make my work easy? Will it be easy to format the hard drive, install 32-bit XP on the 2nd hard drive(D: ) and then proceed with installing 64-bit vista on the 1st hard drive(C: ) (or) the other way around? Thank you in advance for your valuable input. I wish you all a great year ahead!! Cheers, Mahesh You may find these useful How to dual-boot Vista with XP (with XP installed first) - step-by-step guide with screenshots Dual Boot Vista and XP with Vista already installed - SysChat Hope it helps SIW2 |
| | Re: Help installing 32-bit XP PRO on existing 64-bit Vista Ultimate Save yourself some time/trouble and download Virtual Server 2007 (it's free). That way, you can load any OS that you want into a Virtual Session on your Vista machine. You can access all your hardware from the Virtual XP box, that you'd have trouble finding drivers for. That's why I don't recommend downgrading, unless you have the drivers beforehand. I've seen too many failed attempts. - David "mahesh_australia" <guest@xxxxxx-email.com> wrote in message news:90c9169cb9aee61db5bb65404c87bde3@xxxxxx-gateway.com... Quote: > > Hi Everyone, > > Wishing all a happy new year... > > I have HP Pavilion dv9205TX laptop with the following configuration: > 64-bit core2duo 2GHz processor, 2G RAM, 2X160G HDD, 64-bit Vista > Ultimate on the 1st hard drive (C: ) > > I want to install 32-bit Win XP PRO SP3 on the 2nd hard drive (D: ) > > I wanted to know if this is a straight forward installation by choosing > the drive letter D: during the installation or do I still need to use > the software like EasyBCD or VistaBootPro? Which of these softwares will > make my work easy? > > Will it be easy to format the hard drive, install 32-bit XP on the 2nd > hard drive(D: ) and then proceed with installing 64-bit vista on the 1st > hard drive(C: ) (or) the other way around? > > Thank you in advance for your valuable input. > > I wish you all a great year ahead!! > > Cheers, > Mahesh > > > -- > mahesh_australia |
| Vista Ultimate 64bit | Re: Help installing 32-bit XP PRO on existing 64-bit Vista Ultimate Hi David, Thanks for your suggestion. I will be using 64-bit vista ultimate for my personal use and planning to create another admin user & install the virtual server 2007 and then XP PRO SP3 that I'll be using for my office work. Do you recommend me to use Virtual PC 2007 or Virtual Server 2007? If virtual server 2007, do u think it will support vista 64 bit? |
| Re-installing Vista Ultimate | Vista installation & setup | |||
| Ghost/non-existing disc drive appeared after installing hard driv | Vista hardware & devices | |||
| Installing Vista 32 bit over existing 64 bit | Vista installation & setup | |||
| installing Vista OEM ultimate over a previous Vista OEM ultimate? | Vista installation & setup | |||
| RE-INSTALLING XP ALONGSIDE EXISTING VISTA | Vista General | |||
