Drive Letter Problem - Vista Installation
  1. #1
    =?Utf-8?B?Q0VT?= Guest
    All,
    I was wondering if anyone knows how to install Vista where the OS
    partition uses the D: Letter and not C:
    I normally install my OS as fallows:
    C: temp directory (page File) (Primary Partition) (Fat32)
    D: Windows Directory (Logical Drive) (NTFS)
    E: Programs (Logical Drive) (NTFS)
    F: Data Files (Logical Drive) (NTFS)
    I've gotten use to this structure and would like to continue it...
    however when I did my first install of Vista (I did it from my WinXP
    installation) Vista took the drive letter I had temporarily assigned
    the partition Z:. My second attempt was booting to the setup disk but
    Vista took the C: drive Letter and assigned the Primary Partition a
    drive letter of D:.
    I would like the install to be as followes:
    D: Vista Directory (Logical Drive) (NTFS)
    I realize this is a little anal but... If anyone can help it will be
    much appreciated. Thanks in advance. - CES
  2. #2
    mikeyhsd Guest
    Re: Drive Letter Problem - Vista Installation
    normally if you install from another OS, vista will take the partition letter of the designated partition.
    you should format the partition prior to using the vista dvd.
    boot into your xp and then insert the vista dvd in the drive.
    select the "D" partition.
    do not knof it it being a LOGICAL drive will make a difference. I always use PRIMARY partitions.
    mikeyhsd@sport.rr.com
    "CES" <CES@discussions.microsoft.com> wrote in message news:F5333326-3834-4235-9C45-8D59A9B20122@microsoft.com...
    All,
    drive letter of D:.
Drive Letter Problem - Vista Installation problems?
problem re-assigning drive letter Tom Vista General 2 04 Nov 2009
Vista SATA II Hard Drive Installation Problem Drew30 Vista General 7 12 Mar 2008
Vista changes drive letter Meelis Lilbok Vista installation & setup 3 23 Nov 2007
Problem with missing drive letter badun Vista General 0 09 Aug 2007
Vista installation can't allocate drive letter Steven Vista installation & setup 1 27 Apr 2007
