Help with cd/dvd - Not working!!
  1. #1
    Newbie
    Vista Home Premium 32bit
    Local Time: 10:13 AM
    usa us texas
    Okay so everytime I put a cd or dvd into my computer it doesn't read at all like does absolutely nothing. I THINK that's the drive I have..Can anyone help? Thanks if you can!!
    Optiarc CD-RW CRX880A ATA
    It says...
    "Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
    Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available."
  2. #2
    Windows Vista Home Premium SP2 64-bit
    Local Time: 03:13 PM
    usa us connecticut
    Re: Help with cd/dvd - Not working!!
    The same thing happened to me on my Gateway laptop, but I have Optiarc AD-7563A. I resolved this issue by contacting Gateway live chat support. They told me the following: open regedit (Registry Editor) and navigate to HKLM\System\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and to delete values UpperFilter and/or LowerFilter. I then rebooted and problem solved. The long string of letters and numbers will probably be different for your Optiarc model. I suggest contacting your computer manufacturer and trying to get live chat support. Let me know how it works out.
My 32-bit browsers and Skype are not working online but My 64-bit browser is working hankyhat Browsers & Mail 5 05 Oct 2009
windows vista restore not working/blue screen help/safe mode not working rrr666 Vista General 4 25 Jul 2009
MS Intellipoint stopped working but ctrl panel says working proper Susan C. Vista hardware & devices 0 11 Jun 2008
Re: Right click stops working/New tabs stop working/Menu bar disappear Robert Aldwinckle Vista performance & maintenance 9 20 Nov 2007
Creative Audigy 2 drivers working on Vista Working SlickWilly Vista hardware & devices 3 25 Jun 2006
