| Vista Home Premium 32bit | Problem installing home premium 32 bit oem Just finished putting together my first ever build. A very basic one just for home and web and to (hopefully) play with vista. This is a new machine and a clean install (new HD).All my parts are new and all except ram and graphics board are from e buyer. System build Cooler master Elite 330 Black Case With CM extreme Power 460W PSU Western Digital WD2500AAKS Caviar SE 250GB 7200RPM SATAII/300 16MB Cache - OEM ASUS M2N68 nForce 630a Socket AM2+ 8 channel audio ATX Motherboard AMD Athlon 64 X2 5200+ Socket AM2 2.7GHz Energy Efficient L2 1MB (2x512KB) Retail Boxed Processor Optiarc AD-7200S 20X DVD±RW/DL/RAM Internal SATA Bare Black Drive - OEM Xilence Red Wing 120mm Quiet Fan - 3&4pin connection Microsoft Windows Vista Home Premium -SP1- Licence and media - 1 PC - OEM - DVD - 32-bit - English CT2KIT12864AA800 2GB kit (1GBx2), 240-pin DIMM Upgrade for a ASUS M2N68 System x2 from crucial Graphics Xfx geforce8800gs Brand new system no software/os ever installed previously. My issue is the installation of the vista OEM pack. After wasting several hours trying to install this (about 4 times) I am asking the forum members for any resolution they may be able to give. This installation is slow but the main issue is that when I reach the product activation key section I start to have problems. I have input the key then clicked the next button. After a wait I get a new box come up asking me to insert windows installation disc 1. (The OEM came as 1 disc only) If I click cancel it wants to cancel the whole installation. If I click ok it will keep coming up until I get this error message. “Windows cannot open the required file D\scources\install\wim. Make sure all files required for the installation are available and restart the installation. Error code 0x8007000D.” Why would it ask for installation discs for a complete installation when I only have 1 disc and I am not doing an upgrade. On the disc it mentions that it includes windows anytime upgrade, don’t know if this may have any bearing on this. Hope someone may have some ideas as I would like to set up my new build and update ASAP. Regards Sphinx |
| Vista X64 Ultimate | Re: Problem installing home premium 32 bit oem OK do you have a CD disk or a DVD disc, Vista is DVD size & if you have a single CD you do not have all the files you need, in CD form Windows Vista 32 bit is 5 CD's this might be your trouble?? ~wolfcaller ps got that error a few times on a Biostar (NO I did not buy that ... thing). did a Bios Flash (after hunting down a floppy drive & 3.5 disk as thats the only way to flash Biostar's BIOS). |
| Installing Vista Home x64 Premium Problem | Vista installation & setup | |||
| Installing new Vista Home Premium OEM | Vista installation & setup | |||
| Installing Vista Home basic with Home Premium DVD | Vista General | |||
| Installing VPC on Vista Home Premium | Vista installation & setup | |||
| Installing Vista RTM Home Premium.......... | Vista General | |||
