| Guest | Monitor issue or full instal issue After the first restart in the install, (only half way though the process bar) It tells me it will need to restart more times. It just sits there, monitor black, monitor not doing anything. I restart on my own, it loads to the Vista, shows the progress bar in the beginning similar to the XP one, once loaded, monitor goes black again, says "Unable to connect" to something like that. I'm not sure if it's because the install is going wrong, or my monitor is not compatible (I tried 2 monitors) I'm doing a custom install on my F:\ Drive, booting it off a DVD before Windows starts. |
| Guest | RE: Monitor issue or full instal issue Same type of problem here. I'm having the same problem, I tried the ISO direct to hard drive install but at around 80-90% just got hung and my monitor became de-activated giving me just a black screen. I waited 20 minutes to no avail and then restarted with a roll-back to my previous windows XP. Then I tried to install the 32-bit version using the CD I ordered from Microsoft and the precise same thing happened. It goes all the way to about 85% and then just sort of crashes, de-activating my display again and forcing me to restart manually. My system is a Windows XP SP2 with 940 Gigs of HDD space, 2G Ram, 3.46GHZ, with Dual Nvidia SLI Graphics cards. I can't possibly imagine what's going on. I successfully installed Vista on another Notebook computer I have with hardly the same characteristics. What gives??????? I'm thinking that I'll have the same problem with the official public release version. "DaymItzJack" wrote: > After the first restart in the install, (only half way though the process > bar) It tells me it will need to restart more times. It just sits there, > monitor black, monitor not doing anything. I restart on my own, it loads to > the Vista, shows the progress bar in the beginning similar to the XP one, > once loaded, monitor goes black again, says "Unable to connect" to something > like that. I'm not sure if it's because the install is going wrong, or my > monitor is not compatible (I tried 2 monitors) > > I'm doing a custom install on my F:\ Drive, booting it off a DVD before > Windows starts. |
| Guest | RE: Monitor issue or full instal issue I got it working, I just made my computer sleep (After about an hour or two, I hit the button on my keyboard) woke it back up, and the screen worked. I have to do that every time I restart. "rmk" wrote: > Same type of problem here. > I'm having the same problem, I tried the ISO direct to hard drive install > but at around 80-90% just got hung and my monitor became de-activated giving > me just a black screen. I waited 20 minutes to no avail and then restarted > with a roll-back to my previous windows XP. Then I tried to install the > 32-bit version using the CD I ordered from Microsoft and the precise same > thing happened. It goes all the way to about 85% and then just sort of > crashes, de-activating my display again and forcing me to restart manually. > > My system is a Windows XP SP2 with 940 Gigs of HDD space, 2G Ram, 3.46GHZ, > with Dual Nvidia SLI Graphics cards. I can't possibly imagine what's going > on. I successfully installed Vista on another Notebook computer I have with > hardly the same characteristics. > > What gives??????? I'm thinking that I'll have the same problem with the > official public release version. |
| Full Text Search Issue | Live Mail | |||
| Troubleshooting a disk full issue in Vista | Vista General | |||
| Monitor Issue | Graphic cards | |||
| Another comment on the upgrade or full install issue | Vista installation & setup | |||
| monitor issue | Vista hardware & devices | |||
