Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - .NET Framework 3.5 SP1 install problem ---- Please Help
Old 09-01-2009   #1 (permalink)
John Monahan
I hope somebody can help me out here.
I just got Expression Web V3. It tells me I don't have .NET Framework 3.5
SP1 installed.
When I download the .NET SP1 from MS it installs about half way then says
an error was detected and unwinds everything.
The error box says "see Error Log". What error log? where? When I click on
it, MS Visual Studio 2008, it comes up but has its own error box "file
cannot be opened because it is being used by another application".
Talk about frustrating!
I reinstalled/repaired .NET 3.5 it went fine -- at least no errors reported.
Besides Visual Studio 2008, I show
..NET Component Framework 1.0 SP3 developer
..NET Component Framework 2.0 SP2
..NET Component Framework 3.5
..NET Framework 3.5
Really could use some suggestions here as I just want to get Ex Web 3.0
going.
If this is not the best posing site please suggest an alternative
Old 09-03-2009   #2 (permalink)
John Monahan
Re: .NET Framework 3.5 SP1 install problem ---- Please Help
Followup...
I removed all .NET's, removed Visual Studio 2008 and reinstalled it. It put
..NET 3.5 back (only).
Still could not load .NET .SP1
Got the following error in the event viewer log (Windows logs,Setup):-
The Windows update "Update for Windows (KB948610)" could not be installed
because of an error: 2147956403 "The referenced assembly is not installed on
your system." (Command line: ""C:\Windows\system32\WUSA.exe"
"C:\Users\JOHNMO~1\AppData\Local\Temp\dotnetfx3530729.01\1033\dotnetmsp\x86\NetFX3.0-KB948610-v6001-x86.msu"
/quiet /norestart")
Any suggestions anybody
"John Monahan" <monahan@xxxxxx> wrote in message
news:%23DOMYD2KKHA.4136@xxxxxx
> SP1 installed.
> reported.
> .NET Framework 3.5
> going.
Old 09-04-2009   #3 (permalink)
Vista Bussiness x64 PL
Quote  Quote: Originally Posted by John Monahan View Post
Followup...
/quiet /norestart")
> SP1 installed.
> reported.
> .NET Framework 3.5
> going.
How did you remove NET Framework 3.5? Only classic Control Panel>>Programs and Features? -it's not enough.Remove NET Framework 3.5 by using NET Framework Cleanup Tool by Aaron Stebner Aaron Stebner's WebLog : What to do if other .NET Framework setup troubleshooting steps do not help
Old 09-06-2009   #4 (permalink)
John Monahan
"Flavius" <guest@xxxxxx-email.com> wrote in message
news:27d386b317c2bd98175f09736cafe3f4@xxxxxx-gateway.com...
Quote:
> John Monahan;1128055 Wrote:
Quote:
>> Followup...
>> put
>> installed
>> installed on
>> /quiet /norestart")
>> news:%23DOMYD2KKHA.4136@xxxxxx> > >
>> > 3.5
>> > > SP1 installed.
>> > says
>> > click on
>> > "file
>> > > reported.
>> > > .NET Framework 3.5
>> > 3.0
>> > > going.
> by using NET Framework Cleanup Tool by Aaron Stebner 'Aaron Stebner's
> do not help'
> (http://blogs.msdn.com/astebner/archi...11/479928.aspx)
> Flavius
Tried that. I removed all .NET listings and then ran the above program
twice. When I tried to install the .NET 3.5 + SP1 it proceeded as usual
about half way and then aborted. Same errot in System Error Log
/quiet /norestart")
Old 09-07-2009   #5 (permalink)
Make sure Windows Installer service set to MANUAL and Windows Update service set AUTO (DELAYED) and BITS services AUTO (DELAYED) -if these services are disabled you have to correct it,
Try reinstall Windows Update Agent Description of the Windows Update Stand-alone Installer (Wusa.exe) and of .msu files in Windows Vista and in Windows Server 2008
diagnose also BITS service An update is available to fix a Background Intelligent Transfer Service (BITS) crash on a Windows Vista-based computer
and whole WU components How do I reset Windows Update components?
Old 09-07-2009   #6 (permalink)
John Monahan
Thanks Flavius,
I gave up and want back to a 1 year old WHS backup and started from there. A
real pain to reconstruct everything but at least I think I am ready for W7.
John
news:81eaf93ae016f562a1bc938072a4d354@xxxxxx-gateway.com...
> Try reinstall Windows Update Agent 'Description of the Windows Update
> Vista and in Windows Server 2008'
> (http://support.microsoft.com/kb/934307)
> diagnose also BITS service 'An update is available to fix a Background
> Vista-based computer' (http://support.microsoft.com/?kbid=940520)
> and whole WU components 'How do I reset Windows Update components?'
> (http://support.microsoft.com/kb/971058)
> Flavius
MS .NET Framework 3.5 SP1 - Failed Install Windows Updates
help me plss... can't install .net Framework... Vista hardware & devices
***.Net Framework does not install on Vista x64*** Software
Unable to install .net framework 1.1 Vista installation & setup
.net Framework 1.1 Install error Vista installation & setup
