Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Vista Install with GPT error_help!!
Old 10-19-2009   #1 (permalink)
32 bit
Hello. I am trying to load Vista 32 onto my macpro. I came across ur solution on the GPT issue when trying to install the error message - "The selected disk is of the GPT partition style"
So I proceeded to select shift plus F10 to perform a conversion from GPT to MBR. I did this and it worked fine until I clicked continue. I received the error message that "Windows is unable to find a system volume that meets it's criteria for install" and can't proceed. P{lease help, plus the 3 terabyte drive that was completely available and was going to install vista on, now does not show up on my desktop anymore.
Ugg. please help!!
Vista SP2 will not Install(error 0x80070002),In Place Upgrade Repair Install General Discussion
RE: Remote control applet wont install or even prompt to install-vista Virtual Server
Re: Vista Home Premium Install Hangs At Completing. (Clean Install) Vista installation & setup
Can't Install Vista Home premium upgrade - "can't install a file and quits Vista installation & setup
Promise FastTrak S150 TXplus Install Vista B2 install success!(do Vista General
