| | Dual monitor problem intel 82852/82855 chipset/video card Hi NG, I use a Dell Latitude D400 notebook with the mentioned chipset. Basically Vista RC1 and Final are running (without Aero of course). In the display settings I check "Extend the desktop onto this monitor" and "This is my main monitor" for the second (external) monitor. After applying this setting only the internal monitor is running. If I try "Extend the desktop onto this monitor" only it does what it is expected to. Does anybody have an idea what do? Under XP this has been working fine. I've been looking on Intel's website fpr new drivers but couldn't find any. Tried older (XP) drivers, too. All the same. I'd be happy for any replies. Thanks Linus Schroeder |
| Vista Business 32 | Re: Dual monitor problem intel 82852/82855 chipset/video card This is exactly the same problem that I had, but I found a solution that works at least on my computer. Have a look at this posting: Intel 82852/82855 GM/GME Display |
| XPost: Dual monitor problem intel 82852/82855 chipset/video card | Vista hardware & devices | |||
| Dual monitor support on Intel 82852/82855? | Vista hardware & devices | |||
| Re: Any Hope for Intel 82852/82855 Video Driver | Vista hardware & devices | |||
| Intel 82852/82855 appears with 0MB Video memory | Vista hardware & devices | |||
