| | Weird shutdown/startup problem Recently installed Vista on a new computer; I threw in an older Raptor drive in it initially while waiting for new drive-everything was running properly. After putting in new drive (Western Digital drive-WD 320GB SATA WD3200AAKS) and reinstalling fresh copy of Vista, a weird thing started to happen. When I shutdown Vista it does what its supposed to do (shuts down, computer shuts off) then 5 seconds later the computer turns on and reboots....Vista starts normally, etc. I looked all through the BIOS settings and can't find what might be causing this to happen...all other aspects of hardware/OS, etc running normally. The motherboard is a MSI P965 (Intel 965 chipset) NEO F, Intel 6400, 667mhz DDR2... I'm wondering if this is a sleep/hibernation issue gone bad or what.... Any help would be appreciated. -Joe |
| | Re: Weird shutdown/startup problem Double check your BIOS settings for any 'wake on' conditions. Wake on LAN is a very common problem if you are always connected. "Joseph Macari" <jmacari1@cox.net> wrote in message news:u0w0ekbMHHA.1252@TK2MSFTNGP02.phx.gbl... > Recently installed Vista on a new computer; I threw in an older Raptor > drive in it initially while waiting for new drive-everything was running > properly. After putting in new drive (Western Digital drive-WD 320GB SATA > WD3200AAKS) and reinstalling fresh copy of Vista, a weird thing started to > happen. When I shutdown Vista it does what its supposed to do (shuts > down, computer shuts off) then 5 seconds later the computer turns on and > reboots....Vista starts normally, etc. > > I looked all through the BIOS settings and can't find what might be > causing this to happen...all other aspects of hardware/OS, etc running > normally. The motherboard is a MSI P965 (Intel 965 chipset) NEO F, Intel > 6400, 667mhz DDR2... > > I'm wondering if this is a sleep/hibernation issue gone bad or what.... > > Any help would be appreciated. > > -Joe > |
| | Re: Weird shutdown/startup problem John- Thanks....that did it. I had added a firewire PCI card yesterday; there is a setting for "wake up by PCI device" in one of the bios screens that I missed...I guess the firewire card was triggering the restarting........ -joe "John Barnes" <jbarnes@email.net> wrote in message news:OHuD1FcMHHA.3952@TK2MSFTNGP02.phx.gbl... > Double check your BIOS settings for any 'wake on' conditions. Wake on LAN > is a very common problem if you are always connected. > > "Joseph Macari" <jmacari1@cox.net> wrote in message > news:u0w0ekbMHHA.1252@TK2MSFTNGP02.phx.gbl... >> Recently installed Vista on a new computer; I threw in an older Raptor >> drive in it initially while waiting for new drive-everything was running >> properly. After putting in new drive (Western Digital drive-WD 320GB >> SATA WD3200AAKS) and reinstalling fresh copy of Vista, a weird thing >> started to happen. When I shutdown Vista it does what its supposed to do >> (shuts down, computer shuts off) then 5 seconds later the computer turns >> on and reboots....Vista starts normally, etc. >> >> I looked all through the BIOS settings and can't find what might be >> causing this to happen...all other aspects of hardware/OS, etc running >> normally. The motherboard is a MSI P965 (Intel 965 chipset) NEO F, Intel >> 6400, 667mhz DDR2... >> >> I'm wondering if this is a sleep/hibernation issue gone bad or what.... >> >> Any help would be appreciated. >> >> -Joe >> > |
| Problem with Vista shutdown/startup | General Discussion | |||
| Weird startup problem | General Discussion | |||
| Weird Vista network startup problem | Vista General | |||
| Weird Vista network startup problem | Vista networking & sharing | |||
| Weird problems with startup | Vista performance & maintenance | |||
