Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - UAC problem and camera driver
Old 06-10-2006   #1 (permalink)
Kip
Re: UAC problem and camera driver
the desktop.ini files should not normaly show up, unless you have "show
hidden files and folders" set in your folder options. I'm not sure deleting
them will have any effect, but you might want to leave them just to be sure,
it could affect how your desktop is displayed.
in case you're wondering how you have 2 files with the same name in the same
folder, they're not in the same folder. one is in your personal profile, the
other is in the "Public" profile ("All Users" on XP).
Not sure about the AV, though. you might try uninstalling it, then run the
installation program as administrator. be sure to post back here if it works
(or if it doesn't).
"Mr. Newt" wrote:
> TWO (2) desktop.ini files
> "Mr. Newt" <lektrikpuke@yahoo.com> wrote in message
> news:028E3C37-5E45-4186-9BA0-E8348AEAE4AC@microsoft.com...
> > Also, forgot to mention: I now have to desktop.ini files showing on the
> > desktop. Why? Can I safely delete them?
> > Thanks.
> > Robert
> > news:9133678A-57BB-4A1F-AF96-C4D39FC4DD08@microsoft.com...
> >>I installed free antivirus software (THANK YOU CA) on my vista box, but
> >>UAC asks if it's okay to run each time the computer starts. I turned off
> >>UAC, and of course the problem goes away, but returns when I turn it back
> >>on (I was hoping it would accept the virus program because it was there
> >>before being turned on).
> >> Is there a way around this? I don't see any where where I can choose
> >> "remember this setting" and it doesn't seem to save on its own.
> >> Also, anybody know a way to get my logitech camera working with vista?
> >> Thanks Robert
Old 06-10-2006   #2 (permalink)
Mr. Newt
Kip,
I have tried to gain access to vista via Administrator account but can't do
it unless I go through safe mode (which I assume is not the way to install a
program). I've done many things (google it) but none have worked. I've
tried setting it to CTL-ALT-DEL to login, I've made sure Admin account is
active (not disabled) via userpasswords2, I've tried shift-F10 and alt-TAB.
How do I login as Admin?
Also, I tried MS Help's suggestion to fix the problem by going to the
program in question, right clicking, properties, compatibility mode, running
in Administrator mode, and UAC still complains. Just FYI.
Thanks.
Robert
news:1D791431-51DC-4C40-9FDE-EDA5B97B6498@microsoft.com...
> Kip,
> Thanks for the info. Yes, you are right, I have my folders set to show
> hidden files, but they're showing on the desktop. Interesting. I'll try
> the AV solution and will post back.
> Robert
> "Kip" <Kip@discussions.microsoft.com> wrote in message
> news:1DA35215-9654-44DB-99D3-00ACD40EC118@microsoft.com...
>> deleting
>> sure,
>> same
>> the
>> the
>> works
>> (or if it doesn't).
>>> > the
>>> > Thanks.
>>> > Robert
>>> >>but
>>> >>off
>>> >>back
>>> >>there
>>> >> vista?
>>> >> Thanks Robert
Old 06-11-2006   #3 (permalink)
Mr. Newt
I installed free antivirus software (THANK YOU CA) on my vista box, but UAC
asks if it's okay to run each time the computer starts. I turned off UAC,
and of course the problem goes away, but returns when I turn it back on (I
was hoping it would accept the virus program because it was there before
being turned on).
Thanks Robert
Old 06-11-2006   #4 (permalink)
Mr. Newt
Thanks.
Robert
>being turned on).
> Thanks Robert
Old 06-11-2006   #5 (permalink)
Mr. Newt
> Thanks.
> Robert
>> Thanks Robert
Old 06-11-2006   #6 (permalink)
Mr. Newt
Kip,
Robert
> deleting
> sure,
> same
> the
> works
> (or if it doesn't).
>> > the
>> > Thanks.
>> > Robert
>> >>off
>> >>back
>> >> Thanks Robert
Old 06-11-2006   #7 (permalink)
BeckyWC
I'm also having this same problem as well, with the same anti-virus programs
as well. Anyone know how to fix this?
"Mr. Newt" wrote:
> Kip,
> Thanks.
> Robert
> > Kip,
> > Robert
> >> deleting
> >> sure,
> >> same
> >> the
> >> the
> >> works
> >> (or if it doesn't).
> >>> > the
> >>> > Thanks.
> >>> > Robert
> >>> >>but
> >>> >>off
> >>> >>back
> >>> >>there
> >>> >> vista?
> >>> >> Thanks Robert
Old 06-11-2006   #8 (permalink)
Mr. Newt
Becky,
I'm beginning to think there is no fix short of turning off UAC, which I
don't want to do (I think UAC is a good idea). I wish there was a "remember
this setting" button for UAC, which the firewall/security programs I've used
in the past always had. Hint, hint.
Robert
"BeckyWC" <BeckyWC@discussions.microsoft.com> wrote in message
news:FDD57B69-458B-47E1-A472-9815147B89DD@microsoft.com...
> programs
> "Mr. Newt" wrote:
>> Kip,
>> do
>> install a
>> alt-TAB.
>> running
>> Thanks.
>> Robert
>> > Kip,
>> > try
>> > Robert
>> >> "show
>> >> deleting
>> >> sure,
>> >> the
>> >> same
>> >> profile,
>> >> the
>> >> the
>> >> works
>> >> (or if it doesn't).
>> >>> > on
>> >>> > the
>> >>> > Thanks.
>> >>> > Robert
>> >>> >>but
>> >>> >>turned
>> >>> >>off
>> >>> >>it
>> >>> >>back
>> >>> >>there
>> >>> >> choose
>> >>> >> vista?
>> >>> >> Thanks Robert
Old 06-11-2006   #9 (permalink)
Mr. Newt
Okay, I finally tried to uninstall and reinstall in Admin account using
safemode (couldn't figure out how to get into Admin account any other way)
and the problem still exists, so this is not a fix. I will monitor the NG
to see if someone does come up with a solution.
In the meantime I see no alternative to turning UAC off. It doesn't bother
me as much now, though, as I didn't need a password to access the
Administrator account (and install the virus software) in safemode. I hope
this password not being required problem is because of a setting I changed
or because the software is a beta, as it defeats ALL of the security built
into Vista.
Robert
news:40B8A786-219C-44EB-9C3B-0508521460DD@microsoft.com...
> Becky,
> "remember this setting" button for UAC, which the firewall/security
> programs I've used in the past always had. Hint, hint.
> Robert
>> programs
>> "Mr. Newt" wrote:
>>> Kip,
>>> do
>>> install a
>>> is
>>> alt-TAB.
>>> running
>>> Thanks.
>>> Robert
>>> > Kip,
>>> > show
>>> > try
>>> > Robert
>>> >> "show
>>> >> deleting
>>> >> be
>>> >> sure,
>>> >> the
>>> >> same
>>> >> profile,
>>> >> the
>>> >> run
>>> >> the
>>> >> it
>>> >> works
>>> >> (or if it doesn't).
>>> >>> > on
>>> >>> > the
>>> >>> > Thanks.
>>> >>> > Robert
>>> >>> >>box,
>>> >>> >>but
>>> >>> >>turned
>>> >>> >>off
>>> >>> >>it
>>> >>> >>back
>>> >>> >>there
>>> >>> >> choose
>>> >>> >> vista?
>>> >>> >> Thanks Robert
Old 06-11-2006   #10 (permalink)
Kip
I still haven't found a solution either. you can set a password for the admin
account. control panel->user accounts->Advanced
options->advanced->advanced->users, right click administrator, and "set
password". (a lot of steps, I know.) when I set up my system, it asked me to
create a new admin account, and automatically disabled the built-in one.
> into Vista.
> Robert
> > Becky,
> > Robert
> >> programs
> >> "Mr. Newt" wrote:
> >>> Kip,
> >>> do
> >>> install a
> >>> is
> >>> alt-TAB.
> >>> running
> >>> Thanks.
> >>> Robert
> >>> > Kip,
> >>> > show
> >>> > try
> >>> > Robert
> >>> >> "show
> >>> >> deleting
> >>> >> be
> >>> >> sure,
> >>> >> the
> >>> >> same
> >>> >> profile,
> >>> >> the
> >>> >> run
> >>> >> the
> >>> >> it
> >>> >> works
> >>> >> (or if it doesn't).
> >>> >>> > on
> >>> >>> > the
> >>> >>> > Thanks.
> >>> >>> > Robert
> >>> >>> >>box,
> >>> >>> >>but
> >>> >>> >>turned
> >>> >>> >>off
> >>> >>> >>it
> >>> >>> >>back
> >>> >>> >>there
> >>> >>> >> choose
> >>> >>> >> vista?
> >>> >>> >> Thanks Robert
I need LG USB PC Camera driver... Drivers
Need help with camera driver installation Vista hardware & devices
Digital Camera Driver Vista hardware & devices
Driver for Digital Camera Vista hardware & devices
Sony Camera driver problem Vista hardware & devices
