| | turns 5.1 sound into 2-speaker sound only This is getting frustrating. My integreated AC 97 Realtek sound built into the motherboard was "updated" by Vista on install of the OS. But it's turned it into 2-speaker sound instead of 5.1, even after uninstalling and reinstalling several times. It MAY (doesn't always) show up as 5.1 speakers when I try to configure them, but sound is only delivered through the right and left front speakers, either in the test or in practice. Speaker connections are good. Now here's what gets even weirder: I went out and bought a Sound Blaster Audigy SE, downloaded the Vista drivers and software apps from Creative.com, plugged in my speakers to the 5.1 ports on the card, and Vista recognizes it ONLY as stereo speakers, and when I click on Configure, nothing happens. I can't change it. So what's going on and does anybody have any idea about how to fix this? Sorry about crossposting, but didn't know what specific group could address this. Thanks. John |
| | Re: turns 5.1 sound into 2-speaker sound only well thats odd cos i managed to get 5.1 from my realtek AC 97 card i just installed my motherboard drivers then update that way and it worked cos wien i installed vista my S/C didnt register "A" <A@A.net> wrote in message news:%235RMxv3SHHA.1180@TK2MSFTNGP05.phx.gbl... > This is getting frustrating. > > My integreated AC 97 Realtek sound built into the motherboard was > "updated" by Vista on install of the OS. But it's turned it into 2-speaker > sound instead of 5.1, even after uninstalling and reinstalling several > times. > > It MAY (doesn't always) show up as 5.1 speakers when I try to configure > them, but sound is only delivered through the right and left front > speakers, either in the test or in practice. Speaker connections are good. > > Now here's what gets even weirder: I went out and bought a Sound Blaster > Audigy SE, downloaded the Vista drivers and software apps from > Creative.com, plugged in my speakers to the 5.1 ports on the card, > and Vista recognizes it ONLY as stereo speakers, and when I click on > Configure, nothing happens. I can't change it. > > So what's going on and does anybody have any idea about how to fix this? > > Sorry about crossposting, but didn't know what specific group could > address this. > > Thanks. > John |
| | Re: turns 5.1 sound into 2-speaker sound only Yep. It is. Decrease my ignorance please. How did you install drivers for your motherboard and where did you find them? "Bravo Computers UK" <bravo.computers@btinternet.com> wrote in message news:u1b8B23SHHA.4076@TK2MSFTNGP05.phx.gbl... > well thats odd cos i managed to get 5.1 from my realtek AC 97 card i just > installed my motherboard drivers then update that way and it worked cos > wien > i installed vista my S/C didnt register > "A" <A@A.net> wrote in message > news:%235RMxv3SHHA.1180@TK2MSFTNGP05.phx.gbl... >> This is getting frustrating. >> >> My integreated AC 97 Realtek sound built into the motherboard was >> "updated" by Vista on install of the OS. But it's turned it into >> 2-speaker sound instead of 5.1, even after uninstalling and reinstalling >> several times. >> >> It MAY (doesn't always) show up as 5.1 speakers when I try to configure >> them, but sound is only delivered through the right and left front >> speakers, either in the test or in practice. Speaker connections are >> good. >> >> Now here's what gets even weirder: I went out and bought a Sound Blaster >> Audigy SE, downloaded the Vista drivers and software apps from >> Creative.com, plugged in my speakers to the 5.1 ports on the card, >> and Vista recognizes it ONLY as stereo speakers, and when I click on >> Configure, nothing happens. I can't change it. >> >> So what's going on and does anybody have any idea about how to fix this? >> >> Sorry about crossposting, but didn't know what specific group could >> address this. >> >> Thanks. >> John > |
| | Re: turns 5.1 sound into 2-speaker sound only The Realtek site has a new Vista driver. "A" <A@A.net> wrote in message news:%235RMxv3SHHA.1180@TK2MSFTNGP05.phx.gbl... > This is getting frustrating. > > My integreated AC 97 Realtek sound built into the motherboard was > "updated" by Vista on install of the OS. But it's turned it into 2-speaker > sound instead of 5.1, even after uninstalling and reinstalling several > times. > > It MAY (doesn't always) show up as 5.1 speakers when I try to configure > them, but sound is only delivered through the right and left front > speakers, either in the test or in practice. Speaker connections are good. > > Now here's what gets even weirder: I went out and bought a Sound Blaster > Audigy SE, downloaded the Vista drivers and software apps from > Creative.com, plugged in my speakers to the 5.1 ports on the card, > and Vista recognizes it ONLY as stereo speakers, and when I click on > Configure, nothing happens. I can't change it. > > So what's going on and does anybody have any idea about how to fix this? > > Sorry about crossposting, but didn't know what specific group could > address this. > > Thanks. > John |
| | Re: turns 5.1 sound into 2-speaker sound only "DandyDon" <drayh01@yahoo.com> wrote > The Realtek site has a new Vista driver. Yes indeed it does. And according to the PDF it should install on XP as well, which I'd like to do before upgrading to Vista. However the version(s, I tried two) that I downloaded won't install on XP and both of them tried to do it in Turkish (presumably because I'm in Turkey and the installer arrogantly assumed that I needed a "Turkish" installation. I hate software that makes decisions like that for me). -- Bob http://www.kanyak.com |
| | #6 (permalink) |
| | Re: turns 5.1 sound into 2-speaker sound only thanks. i'll download it and give it a go. appreciate your help. "DandyDon" <drayh01@yahoo.com> wrote in message news:OP$4oN7SHHA.920@TK2MSFTNGP05.phx.gbl... > The Realtek site has a new Vista driver. > > "A" <A@A.net> wrote in message > news:%235RMxv3SHHA.1180@TK2MSFTNGP05.phx.gbl... >> This is getting frustrating. >> >> My integreated AC 97 Realtek sound built into the motherboard was >> "updated" by Vista on install of the OS. But it's turned it into >> 2-speaker sound instead of 5.1, even after uninstalling and reinstalling >> several times. >> >> It MAY (doesn't always) show up as 5.1 speakers when I try to configure >> them, but sound is only delivered through the right and left front >> speakers, either in the test or in practice. Speaker connections are >> good. >> >> Now here's what gets even weirder: I went out and bought a Sound Blaster >> Audigy SE, downloaded the Vista drivers and software apps from >> Creative.com, plugged in my speakers to the 5.1 ports on the card, >> and Vista recognizes it ONLY as stereo speakers, and when I click on >> Configure, nothing happens. I can't change it. >> >> So what's going on and does anybody have any idea about how to fix this? >> >> Sorry about crossposting, but didn't know what specific group could >> address this. >> >> Thanks. >> John > > |
| losing sound on the right laptop speaker | Sound & Audio | |||
| Sound level not balanced with speaker box | Sound & Audio | |||
| external speaker/sound problem | Vista General | |||
| turns 5.1 sound into 2-speaker sound only | Vista General | |||
| Sound from main speaker and headphone. | Vista General | |||
