| | Installation Problems Hi, i cant seem to get vista to install after numerous trys. My PC is certainly compatible and ive run the upgrade advisor and it shows no imediate problems. everytime i install, after it finishes installing a blank screen comes up with a blinking underscore, after a while it restarts and undoes the changes and tells me it was unsucessful. |
| | Re: Installation Problems mdcdeve <mdcdeve@discussions.microsoft.com> wrote: > Hi, i cant seem to get vista to install after numerous trys. > My PC is certainly compatible and ive run the upgrade advisor and it shows > no imediate problems. > > everytime i install, after it finishes installing a blank screen comes up > with a blinking underscore, after a while it restarts and undoes the changes > and tells me it was unsucessful. try these step by step instructions: http://www.youtube.com/watch?v=LxQm3IsSKAo&eurl if that still doesn't work, try this website. 100% chance these machines will work correct, and provide years of virus free, problem free service. http://www.apple.com/ |
| | Re: Installation Problems Are you doing an upgrade or a clean install? -- HTH, Kevin Spencer Microsoft MVP Software Composer http://unclechutney.blogspot.com The shortest distance between 2 points is a curve. "mdcdeve" <mdcdeve@discussions.microsoft.com> wrote in message news:A36304F9-EC9F-46DC-8831-24C5C7C29092@microsoft.com... > Hi, i cant seem to get vista to install after numerous trys. > My PC is certainly compatible and ive run the upgrade advisor and it shows > no imediate problems. > > everytime i install, after it finishes installing a blank screen comes up > with a blinking underscore, after a while it restarts and undoes the > changes > and tells me it was unsucessful. |
| | RE: Installation Problems Hello, Can you capture the setupact.log and setuperr.log file that is on your system after the failure? C:\$WINDOWS.~BT\Sources\Panther\setupact.log C:\$WINDOWS.~BT\Sources\Panther\setuperr.log send to be me, remove the online. Thanks, Darrell Gorter[MSFT] This posting is provided "AS IS" with no warranties, and confers no rights -------------------- |>Thread-Topic: Installation Problems |>thread-index: AcdLoJ0X1vMqfmy1Tbm9zAdaIZECJA== |>X-WBNR-Posting-Host: 88.111.109.168 |>From: =?Utf-8?B?bWRjZGV2ZQ==?= <mdcdeve@discussions.microsoft.com> |>Subject: Installation Problems |>Date: Thu, 8 Feb 2007 08:46:00 -0800 |>Lines: 7 |>Message-ID: <A36304F9-EC9F-46DC-8831-24C5C7C29092@microsoft.com> |>MIME-Version: 1.0 |>Content-Type: text/plain; |> charset="Utf-8" |>Content-Transfer-Encoding: 7bit |>X-Newsreader: Microsoft CDO for Windows 2000 |>Content-Class: urn:content-classes:message |>Importance: normal |>Priority: normal |>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2757 |>Newsgroups: microsoft.public.windows.vista.installation_setup |>Path: TK2MSFTNGHUB02.phx.gbl |>Xref: TK2MSFTNGHUB02.phx.gbl microsoft.public.windows.vista.installation_setup:6692 |>NNTP-Posting-Host: tk2msftibfm01.phx.gbl 10.40.244.149 |>X-Tomcat-NG: microsoft.public.windows.vista.installation_setup |> |>Hi, i cant seem to get vista to install after numerous trys. |>My PC is certainly compatible and ive run the upgrade advisor and it shows |>no imediate problems. |> |>everytime i install, after it finishes installing a blank screen comes up |>with a blinking underscore, after a while it restarts and undoes the changes |>and tells me it was unsucessful. |> |
| | Re: Installation Problems Hi, i am doing a clean install, first i tried 4 times on my partition and then i partitioned off 20 gb specifically for vista and that failed the same as previous attempts. "Kevin Spencer" wrote: > Are you doing an upgrade or a clean install? > > -- > HTH, > > Kevin Spencer > Microsoft MVP > Software Composer > http://unclechutney.blogspot.com > > The shortest distance between 2 points is a curve. > > "mdcdeve" <mdcdeve@discussions.microsoft.com> wrote in message > news:A36304F9-EC9F-46DC-8831-24C5C7C29092@microsoft.com... > > Hi, i cant seem to get vista to install after numerous trys. > > My PC is certainly compatible and ive run the upgrade advisor and it shows > > no imediate problems. > > > > everytime i install, after it finishes installing a blank screen comes up > > with a blinking underscore, after a while it restarts and undoes the > > changes > > and tells me it was unsucessful. > > > |
| | #6 (permalink) |
| | RE: Installation Problems Hi, do you mean send to Darrellg@microsoft.com? ""Darrell Gorter[MSFT]"" wrote: > Hello, > Can you capture the setupact.log and setuperr.log file that is on your > system after the failure? > C:\$WINDOWS.~BT\Sources\Panther\setupact.log > C:\$WINDOWS.~BT\Sources\Panther\setuperr.log > send to be me, remove the online. > Thanks, > Darrell Gorter[MSFT] > > This posting is provided "AS IS" with no warranties, and confers no rights > -------------------- > |>Thread-Topic: Installation Problems > |>thread-index: AcdLoJ0X1vMqfmy1Tbm9zAdaIZECJA== > |>X-WBNR-Posting-Host: 88.111.109.168 > |>From: =?Utf-8?B?bWRjZGV2ZQ==?= <mdcdeve@discussions.microsoft.com> > |>Subject: Installation Problems > |>Date: Thu, 8 Feb 2007 08:46:00 -0800 > |>Lines: 7 > |>Message-ID: <A36304F9-EC9F-46DC-8831-24C5C7C29092@microsoft.com> > |>MIME-Version: 1.0 > |>Content-Type: text/plain; > |> charset="Utf-8" > |>Content-Transfer-Encoding: 7bit > |>X-Newsreader: Microsoft CDO for Windows 2000 > |>Content-Class: urn:content-classes:message > |>Importance: normal > |>Priority: normal > |>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2757 > |>Newsgroups: microsoft.public.windows.vista.installation_setup > |>Path: TK2MSFTNGHUB02.phx.gbl > |>Xref: TK2MSFTNGHUB02.phx.gbl > microsoft.public.windows.vista.installation_setup:6692 > |>NNTP-Posting-Host: tk2msftibfm01.phx.gbl 10.40.244.149 > |>X-Tomcat-NG: microsoft.public.windows.vista.installation_setup > |> > |>Hi, i cant seem to get vista to install after numerous trys. > |>My PC is certainly compatible and ive run the upgrade advisor and it > shows > |>no imediate problems. > |> > |>everytime i install, after it finishes installing a blank screen comes up > |>with a blinking underscore, after a while it restarts and undoes the > changes > |>and tells me it was unsucessful. > |> > > |
| | #7 (permalink) |
| | Re: Installation Problems Hi Michelle, nice video. But macs arent compatible with any of the programs i use. "Michelle Steiner" wrote: > mdcdeve <mdcdeve@discussions.microsoft.com> wrote: > > > Hi, i cant seem to get vista to install after numerous trys. > > My PC is certainly compatible and ive run the upgrade advisor and it shows > > no imediate problems. > > > > everytime i install, after it finishes installing a blank screen comes up > > with a blinking underscore, after a while it restarts and undoes the changes > > and tells me it was unsucessful. > > try these step by step instructions: > > http://www.youtube.com/watch?v=LxQm3IsSKAo&eurl > > if that still doesn't work, try this website. 100% chance these machines > will work correct, and provide years of virus free, problem free service. > > http://www.apple.com/ > |
| | #8 (permalink) |
| | Re: Installation Problems I personally suggest two things. Before you started this process, your hard drive was not set to dynamic, was it? Mine was, and I had the same issues you're having... In addition, disconnect ALL accessories, i.e. usb items. So, all that should be left is, power, keyboard, mouse, and monitor. If doing an upgrade uninstall anti virus software, and CD burning software, then try again. I bet it works then... "mdcdeve" <mdcdeve@discussions.microsoft.com> wrote in message news:A36304F9-EC9F-46DC-8831-24C5C7C29092@microsoft.com... > Hi, i cant seem to get vista to install after numerous trys. > My PC is certainly compatible and ive run the upgrade advisor and it shows > no imediate problems. > > everytime i install, after it finishes installing a blank screen comes up > with a blinking underscore, after a while it restarts and undoes the > changes > and tells me it was unsucessful. |
| | #9 (permalink) |
| | Re: Installation Problems - Pretty sad indeed and I didn't even get kissed! Yep, it is all pretty sad. I have an almost 'state of the art' newer high end computer with tons of HD space. Until now, it runs anything and everything I've thrown at it. I've built and assembled my last 8 computers so I'm not exactly new at working with operating systems. And of course the current computer with XP Pro easily passes any VISTA compatibility tests. But VISTA is an entirely new and frustrating experience. Regarding VISTA, I've gone from enthusiastic and "I can hardly wait" to absolute disgust. If I were Bill Gates and was tired of having all that money and success, I'd do what he is doing and end it all with the release of a truly uninstallable or unusable operating system. On my computer, VISTA installs fairly well until it "re-sets" the screen to a font size that appears to be consistent with my 1920 x 1200 default screen resolution, then goes into a reboot cycle from which nothing short of "pull the power plug" will recover. There is no advice. There are no helpful messages, in fact no messages whatsoever. After a few minutes of this reboot frustration, I actually expected a happy face to pop up on my screen with a message: "Ha Ha, I have your $400 and you just got f__ked by Microsoft." But alas, I didn't even get that much. On Thu, 8 Feb 2007 08:46:00 -0800, mdcdeve <mdcdeve@discussions.microsoft.com> wrote: >Hi, i cant seem to get vista to install after numerous trys. >My PC is certainly compatible and ive run the upgrade advisor and it shows >no imediate problems. > >everytime i install, after it finishes installing a blank screen comes up >with a blinking underscore, after a while it restarts and undoes the changes >and tells me it was unsucessful. |
| | #10 (permalink) |
| | Re: Installation Problems Hi Navilyn, thanks for your reply. Im pretty sure im not using dynamic though when you say dynamic do you mean discs spanned over mulitple drives? I will try your suggestions though and unplug all peripherals apart from those that are needed. "Navilyn" wrote: > I personally suggest two things. Before you started this process, your hard > drive was not set to dynamic, was it? Mine was, and I had the same issues > you're having... > > In addition, disconnect ALL accessories, i.e. usb items. So, all that should > be left is, power, keyboard, mouse, and monitor. If doing an upgrade > uninstall anti virus software, and CD burning software, then try again. I > bet it works then... > > "mdcdeve" <mdcdeve@discussions.microsoft.com> wrote in message > news:A36304F9-EC9F-46DC-8831-24C5C7C29092@microsoft.com... > > Hi, i cant seem to get vista to install after numerous trys. > > My PC is certainly compatible and ive run the upgrade advisor and it shows > > no imediate problems. > > > > everytime i install, after it finishes installing a blank screen comes up > > with a blinking underscore, after a while it restarts and undoes the > > changes > > and tells me it was unsucessful. > > > |
| Installation problems | Vista General | |||
| Installation Problems | Vista print fax & scan | |||
| Installation Problems | Vista installation & setup | |||
