Wireless / Wired differences ??
  1. #1
    Rene Guest
    Hi, when I connect with my Vista Ultimate notebook to my NAS server with the
    wired 10/100Mb ethernet all is fine, when I do this with the wireless
    connection (intel 3945 chipset) I get no acces to the NAS server or other
    local web-based servers
    Everything is handled with the same wireless router with DHCP configured for
    both connections.
    Connecting to the internet is fine.
    Suggestions ??
  2. #2
    Ed Stoddard Guest
    RE: Wireless / Wired differences ??
    > both connections.
    > Suggestions ??
    Wired connections don't usually have security issues to deal that wireless
    ones do.
    Your wireless connection to the network might require a WEP or WPA key in
    order to allow you in. Without this kind of coded protection, anyone close
    by with a laptop could access your network, and so files. Talk to your IT
    network admistrator about getting the proper code to access the network.
  3. #3
    Rene Guest
    Re: Wireless / Wired differences ??
    >> the
    >> for
    >> both connections.
    > ones do.
    > close
    I'm the administrator :-) I found out it is a problem in the Speedtouch ADSL
    router, incompatible to the RC1332 standard. I contacted the manufacurer and
    they will release a firmware update in the near future.
    Regards
    Rene
Wireless / Wired differences ?? problems?
wireless or wired kiddieboy12 Network & Sharing 1 10 Feb 2009
Wired vs. Wireless Louis-Pierre Dauphinais Vista General 3 18 Sep 2008
wired vs. wireless bassfisher6522 Network & Sharing 2 21 Apr 2008
Wireless NO - Wired Yes Bikini Browser Vista General 3 29 Jan 2008
Wireless NO - Wired Yes Bikini Browser Vista networking & sharing 3 29 Jan 2008
