I am having major problems installing WIndows Vista from a dvd i burned the
iso to do you have any alternative ways in which i can install windows vista
please????!!!
please????!!!
Although it seems there are much problems doing so, you can try to mount the
ISO image with an Image Mounter like DEAMON Tools or similiar and then
install it.
Another possibility is to order the original DVD from Microsoft, but this
will take a month or so (to order go here:
http://www.microsoft.com/windowsvist.../preview.mspx).
Greets
| Similar Threads | ||||
| the problem with ndis.sys Blue Screen of Death problem solved? | liketofindoutwhy | Vista General | 6 | 24 May 2009 |
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Rainald Taesler | Vista mail | 14 | 17 May 2009 |
| Generic McAfee Problem Message in Vista Problem Reports | cyberbuff53 | Vista performance & maintenance | 0 | 01 Dec 2007 |
| fixed unable to delete email problem, now I have new problem | j2 | Vista mail | 19 | 29 Mar 2007 |
| Vista Upgrade Problem - Windows Explorer Loop problem | Steve S | Vista installation & setup | 0 | 27 Jun 2006 |
