1394 connection and D347PRT SCSI CONTROLLER not supported.
  1. #1
    pizzathahut Guest
    [DELL 5160 Inspiron laptop]
    I d/l the 32bit VISTA and X-fer'd it to a DVD no problem. SETUP starts fine
    but during the upgrade install it reports that the SCSI & my 1394 is not
    supported.
    I've gone ahead in tried to re-install VISTA after going ito DEVICE MGR and
    disabling the hardware in question. VISTA still recognizes the devices, had
    to go back into DEVICE MGR and unstall the devices.
    Just wondering if anyone else had this issue and found another way around it?
    P.S.
    Still working on the install, install keeps freezing up after I click
    UPGRADE/update via web install.
  2. #2
    CadTux Guest
    RE: 1394 connection and D347PRT SCSI CONTROLLER not supported.
    THE D347PRT scsi drive is Daemon tools. I had to uninstall Daemon tools
    (after I burned the ISO to DVD) in order to get that to work. As far as your
    1394, if uninstalling does not work via device manager, try disabling tthe
    firewire port in your laptop's BIOS (if possible).
    If that still does not work, I think installing a clean vista will get it
    loaded, but your 1394 will not be supported.
    > supported.
    > P.S.
  3. #3
    pizzathahut Guest
    Yeah I got past the Collecting Information process and into the install from
    [unistalling] all the hardware in question... but then it look slike to
    install froze up on my on the second step. It just hung on 99% complete for
    over an hour.
    Against my better judgement... I'm trying a clean install now....
    > > supported.
    > > P.S.
  4. #4
    WildPointer Guest
    I don't have Daemon tools. I do have D347PTR.sys and I think it has something
    to do with the RAID on my HP Pavilion a1250n. I have uninstalled it but XP
    steathily re-installs it on every re-boot.
    Who wrote it? Where is the update?
    > > supported.
    > > P.S.
  5. #5
    pizzathahut Guest
    WildPointer, just uninstall from Device Manager and do not reboot. Load up
    the install CD once the hardware has been removed. I got my Vista finally
    installed. 7 hours later... but installed and so far running good.
    > > > supported.
    > > > P.S.
  6. #6
    WildPointer Guest
    I did do that. Twice. I still die with BSOD. I wonder if Vista is missing
    SATA drivers? I am not using the IDE except for channel 2 for DVDs. But my
    drives, I think, are not there when Vista tries to come up. Anyway I get BSOD
    and no meaningful error indicating any driver or specific error. Just a
    clueless dump
    > > > > supported.
    > > > > P.S.
  7. #7
    WildPointer Guest
    I did. Twice. I get BSOD. I think it is related to my drive problem. I don't
    use my primary IDE channel. THe secondary is for DVD drives and my HD is
    SATA. I think the SATA drivers are missing
    > > > > supported.
    > > > > P.S.
  8. #8
    WildPointer Guest
    Oops, when I post I get an error saying the post did not take. But clearly it
    is posting... hmmm.
    > > > > > supported.
    > > > > > P.S.
IEEE 1394 Host Controller Vipin Vista hardware & devices 3 28 Jan 2009
Epson & IEEE 1394/FIREWIRE NOT SUPPORTED Phil Vista print fax & scan 1 25 May 2007
SCSI Controller Spontaneous02jg Vista General 7 06 Apr 2007
Vista won't install due to D347PRT SCSI Controller update required Nicpike Vista installation & setup 3 05 Feb 2007
1394 connection and D347PRT SCSI CONTROLLER pizzathahut Vista hardware & devices 0 11 Jun 2006
