ACPI problem but no problem at all - Strange thing
  1. #1
    Marco Guest
    Hi. I have a original disk of windows vista business upgrade. Two weeks ago I
    intalled over a windows xp. No problem at all.
    Yesterday I hard disk died. Today I intall the same original windows xp and
    I try to upgrade to windows vista, but a error appears tells me that Vista
    must be installed on c omputer that supports ACPI.
    Well, Vista was right, on by BIOS setup I had ACPI disable. My mistake. But
    I already Enable it. I tried aain to upgrade to Vista but the same message
    returns.
    Do I must install XP with ACPI enable and only then upgrade to Vista???
    Do I need to format the computer again?
    Regards,
    Marco
  2. #2
    danman32 Guest
    RE: ACPI problem but no problem at all - Strange thing
    > returns.
    > Regards,
    > Marco
    Sometimes you can change the HAL to accomodate the resetting of ACPI. There
    are some KBs on this. However, you are better off doing a repair install of
    XP at best.
  3. #3
    Marco Guest
    Hi Danman. I guess so. At the moment I'm choosing in with partition I want to
    install XP.
    I'll try. If you want I can leave here a post with the result.
    MS
    > > returns.
    > > Regards,
    > > Marco
    > XP at best.
ACPI Problem when trying to install (yes i did search!) Thomas De Grauw Vista installation & setup 1 29 Mar 2007
ACPI problem.... ebar3 Vista hardware & devices 5 10 Mar 2007
ACPI Problem Windows Vista RC1 Lewis Vista General 0 16 Oct 2006
Gateway, ACPI Problem =?iso-8859-1?Q?Rodolfo_Parrado_Guti=E9rrez_=5BMVP=5D?= Vista General 1 07 Aug 2006
Re: Problem with ACPI Tom Tessier Vista installation & setup 2 02 Apr 2006
