LAN problem
  1. #1
    Bernard Liengme Guest
    LAN problem
    Three PCs running Windows XP connected to an ISDL box.
    Internet, file and printer sharing work well.
    Added a PC with Windows Vista
    Stage A: The XP machine continue to work and the Vista machine can use
    Internet and email. But the XP's network (MSHOME) cannot see the Vista
    network (WORKGROUP); nor can the Vista see the XP's
    Changed the network name on the XPs to WORKGROUP.
    Now the XP's see the Vista but cannot access it; Vista still cannot see
    XPs ---call this STAGE B
    Following MS instructions I downloaded and installed the LLTD protocol on
    the XP machines. Back to XP's cannot see Vista and versa-visa. Stage C
    Uninstalled LLTD and back to stage B
    Any ideas? Please!
    Bernard V Liengme
    www.stfx.ca/people/bliengme
    remove caps from email
  2. #2
    canixs Guest
    Re: LAN problem
    Check your firewall on Vista and you have to enable the File and Folder
    sharing service on Vista, it's off by default.
    "Bernard Liengme" <bliengme@stfx.TRUENORTH.ca> wrote in message
    news:eag$wvRWHHA.4384@TK2MSFTNGP02.phx.gbl...
    > Any ideas? Please!
    > Bernard V Liengme
LAN problem
the problem with ndis.sys Blue Screen of Death problem solved? liketofindoutwhy Vista General 6 24 May 2009
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Rainald Taesler Vista mail 14 17 May 2009
Generic McAfee Problem Message in Vista Problem Reports cyberbuff53 Vista performance & maintenance 0 01 Dec 2007
fixed unable to delete email problem, now I have new problem j2 Vista mail 19 29 Mar 2007
Vista Upgrade Problem - Windows Explorer Loop problem Steve S Vista installation & setup 0 27 Jun 2006
