| | VISTA PROBLEM SOLVED>>>>>MUST READ!!! Wow my vista problems solved. How do you say? Well it took 2 Days and 29 Hours!!!! But i got it! Actully everyone that gets those errors with the numbers and image failed to boot and stuff i don't know what all of those mean but really its quite simple. If you try to reinstall windows xp back on to your machine you will see that it can't because the hard drive is damaged...WAIT A MIN...damaged...i got to the install for vista and even formated it from the vista install...whats up with that...well after a while of figuring out i found out that vista sometimes damages the file system on your hard drive...even when reformatting...now i can't be certain, i'm not a professional annalyser, but i reformated, A COMPLETE INSTALL NOT QUICK... and BAAAA BOOOM it works....all you have to do is do a clean full wipe of the hd, if you get these errors, and tada its done. Repost if it works for you as well. |
| | Re: VISTA PROBLEM SOLVED>>>>>MUST READ!!! "Shinzon2006" <Shinzon2006@discussions.microsoft.com> wrote in message news:C8BB341F-1500-486B-9D39-35BD77FCC1D6@microsoft.com... > Wow my vista problems solved. How do you say? Well it took 2 Days and 29 > Hours!!!! But i got it! Actully everyone that gets those errors with the > numbers and image failed to boot and stuff i don't know what all of those > mean but really its quite simple. If you try to reinstall windows xp back > on > to your machine you will see that it can't because the hard drive is > damaged...WAIT A MIN...damaged...i got to the install for vista and even > formated it from the vista install...whats up with that...well after a > while > of figuring out i found out that vista sometimes damages the file system > on > your hard drive...even when reformatting...now i can't be certain, i'm not > a > professional annalyser, but i reformated, A COMPLETE INSTALL NOT QUICK... > and > BAAAA BOOOM it works....all you have to do is do a clean full wipe of the > hd, > if you get these errors, and tada its done. Repost if it works for you as > well. After installing Vista on a spare drive a few times I ran across that problem too of the Vista install program quitting with a copy error. I used Maxblast, cleaned out that drive and the problem was solved. Al |
| How My Windows Vista Mail Problem Was Solved | Vista mail | |||
| Solved Joining Vista to Domain Problem | Vista networking & sharing | |||
| Vista not sleeping problem---SOLVED | Vista General | |||
| Solved my Vista/XP shared printer problem | Vista print fax & scan | |||
| VISTA PROBLEM SOLVED>>>>>MUST READ!!! | Vista installation & setup | |||
