| | Help - Activation problems Im having some trouble activating windows Vista Home Premium (Upgrade). I recently upgraded my computer and replaced every part of my computer except the hard drive. However, I couldnt load the sata drivers and I didnt have a floppy disk so I just used the Windows vista CD I had and installed over my previous installation of vista (the same copy). This cleared my entire hard drive and I thought all it did was reinstall Home premium. When I went to activate it said "This CD Key is already in use" and when I tried to enter the CD Key again it said something along the lines of "this CD was not meant for clean installations." In most cases I would contact technical support but I'm afraid of getting charged $59. Any help please? |
| | Re: Help - Activation problems Use the telephone number supplied for activating Vista via phone. You will not be charged for re-activating a system install that got accidentally wiped out. You can do this as many times as you need to. Bob S. "James" <James@discussions.microsoft.com> wrote in message news:F9DCBF1A-133A-45EC-9CF1-870152EB3CF6@microsoft.com... > Im having some trouble activating windows Vista Home Premium > (Upgrade). > I recently upgraded my computer and replaced every part of my computer > except > the hard drive. However, I couldnt load the sata drivers and I didnt have > a > floppy disk so I just used the Windows vista CD I had and installed over > my > previous installation of vista (the same copy). This cleared my entire > hard > drive and I thought all it did was reinstall Home premium. When I went to > activate it said "This CD Key is already in use" and when I tried to enter > the CD Key again it said something along the lines of "this CD was not > meant > for clean installations." In most cases I would contact technical support > but > I'm afraid of getting charged $59. Any help please? |
| Problems with activation | Vista installation & setup | |||
| Activation Problems | Vista General | |||
| Activation problems | Vista installation & setup | |||
| activation problems | Vista installation & setup | |||
| Activation Problems | Vista installation & setup | |||
