Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Vista Home Premium Retail - 64bit pending - Serial Key question
Old 03-24-2007   #1 (permalink)
miramis82
We bought Windows Vista Home Premium *retail* for my machine today, and I've
already ordered my 64 bit version from Microsoft, I'm guessing the new disc
will be tied to this Serial Key, but can I use it for my 32 bit version in
the meantime?
I want to try and get this new sata drive running and feel my way around any
hardware issues with vista before the 64 bit gets here, apparently it can
take up to a month to arrive. Will there be problems using this Key with the
32bit now and then reusing it when the 64 bit arrives or will my 64 bit be
void if I do?
Old 03-24-2007   #2 (permalink)
HairyMcLeary
Re: Vista Home Premium Retail - 64bit pending - Serial Key question
"miramis82" <miramis82@discussions.microsoft.com> wrote in message
news:6D3B1774-DF36-4FB9-901F-39FCABFEBCF9@microsoft.com...
> I've
> disc
> the meantime?
> any
> the
> void if I do?
By serial key I presume you mean the product key needed for activation
No problem using the key with the 32 bit until the 64 arrives.
The 64 bit install has to be a "clean" installation.
You will need 64 bit drivers for all of your hardware, so it may be a good
idea to see if they are available before you upgrade.
I'm about to go back to 32 bit, my system is noticeably more sluggish under
64 bit and there isn't any real advantage to running 64.
Tony
Old 03-24-2007   #3 (permalink)
Rick Rogers
Yes, you can use it now, and then later with the 64-bit version when it
arrives.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
> I've
> disc
> the meantime?
> any
> the
> void if I do?
Old 03-24-2007   #4 (permalink)
RonK
You don't need to input the Serial Key during the installation.
Leave it blank and select the product you purchased for installation.
You then have a full working Vista for 30 days.
> I've
> disc
> the meantime?
> any
> the
> void if I do?
Old 03-27-2007   #5 (permalink)
miramis82
I'm kind of glad about that because it's all installed and I'm using right
now *grin* Just got to get certain things turned off and set up, blah blah
blah!
"Rick Rogers" wrote:
> Hi,
> arrives.
> Best of Luck,
> > I've
> > disc
> > the meantime?
> > any
> > the
> > void if I do?
Old 03-27-2007   #6 (permalink)
miramis82
> Tony
Yes I meant the Product Key
I'll just format the SATA when the 64bit arrives, it's going to be secondary
to my XP installation until all the hardware/software drivers and such settle
down for games.
Now for the fun of setting up my first SATA drive ever in a (hopefully) dual
boot situation with the existing IDE (XP) drive. What fun..
Installing Vista Home Premium 64bit on a newly built computer; question? Vista installation & setup
Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media Vista installation & setup
Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H Vista General
OEM Vista Home Premium to Ultimate Retail Vista General
Vista RC2 Ultimate to Home Premium Retail Vista General
