| Guest | Installation Problems I'm having an issue with Windows Vista Ultimate. There are certain programs like Windows Live Messenger and BOINC that use Windows Installer & InstallShield Wizard respectively that when I try to install, they take forever to do so. At the time of this posting, I'm waiting for BOINC to actually begin installing and it's been sitting for about 20 minutes now. Is there a way I can fix this problem so that they'll actually install programs faster? I never had this problem when I was running Windows XP as they would install them normally and take at most a couple minutes to finish. |
| Installation problems | Vista General | |||
| Installation Problems | Vista print fax & scan | |||
| Installation Problems | Vista installation & setup | |||
