| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Guest | Problem creating a PPPoA connection I am using a PCI ADSL (Conexant AccessRunner ADSL) under Vista Beta 2. The connection details given to me by my ISP specifiy PPPoA so I have installed the correct drivers for this, with no problems. I can see the System Tray icon and use the Control Panel applet which both show the adapter has made a successful connection. However, when I try to create a connection in Internet Explorer, I only get the option to make a PPPoE connection. When I try this it does not work. Diagnosing the problem gives a message to the effect that my Local Network cable is unplugged, which does not apply to PPPoA. So the problem is I can get a successful connection to broadband - I just can't use it under IE. My questions are:- 1) does Vista support PPPoA, as it is not mentioned anywhere in Help (or in these forums)? 2) If 1) is not relevant to the problem I am having, is there a way of making IE 'recognise' the ADSL adapter under Vista? Thanks, alga |
| Guest | Re: Problem creating a PPPoA connection It appears the PPPoA option is supposed to be provided by the Vendor's driver: · TCP/IP over PPP over ATM (PPPoA) using a vendor DSL ATM miniport driver You can find this in the document at: http://download.microsoft.com/downlo...orkingOver.doc Although this is a win 2003 document, I think it is one of those items that applies in general to most, if not all, versions of Windows. alga wrote: > I am using a PCI ADSL (Conexant AccessRunner ADSL) under Vista Beta 2. The > connection details given to me by my ISP specifiy PPPoA so I have installed > the correct drivers for this, with no problems. I can see the System Tray > icon and use the Control Panel applet which both show the adapter has made a > successful connection. However, when I try to create a connection in > Internet Explorer, I only get the option to make a PPPoE connection. When I > try this it does not work. Diagnosing the problem gives a message to the > effect that my Local Network cable is unplugged, which does not apply to > PPPoA. > > So the problem is I can get a successful connection to broadband - I just > can't use it under IE. > > My questions are:- > > 1) does Vista support PPPoA, as it is not mentioned anywhere in Help (or in > these forums)? > > 2) If 1) is not relevant to the problem I am having, is there a way of > making IE 'recognise' the ADSL adapter under Vista? > > Thanks, > > alga |
| Guest | Re: Problem creating a PPPoA connection "Rick" wrote: > It appears the PPPoA option is supposed to be > provided by the Vendor's driver: > > · TCP/IP over PPP over ATM (PPPoA) using a > vendor DSL ATM miniport driver > > You can find this in the document at: > http://download.microsoft.com/downlo...orkingOver.doc > > Although this is a win 2003 document, I think it > is one of those items that applies in general to > most, if not all, versions of Windows. > > > alga wrote: > > I am using a PCI ADSL (Conexant AccessRunner ADSL) under Vista Beta 2. The > > connection details given to me by my ISP specifiy PPPoA so I have installed > > the correct drivers for this, with no problems. I can see the System Tray > > icon and use the Control Panel applet which both show the adapter has made a > > successful connection. However, when I try to create a connection in > > Internet Explorer, I only get the option to make a PPPoE connection. When I > > try this it does not work. Diagnosing the problem gives a message to the > > effect that my Local Network cable is unplugged, which does not apply to > > PPPoA. > > > > So the problem is I can get a successful connection to broadband - I just > > can't use it under IE. > > > > My questions are:- > > > > 1) does Vista support PPPoA, as it is not mentioned anywhere in Help (or in > > these forums)? > > > > 2) If 1) is not relevant to the problem I am having, is there a way of > > making IE 'recognise' the ADSL adapter under Vista? > > > > Thanks, > > > > alga > > Further information: I set up a default connection called 'f2s', but whenever I try to connect through IE using the 'Always dial my default connection' option, it tries to connect using a one named 'The Internet'. The dialog that appears has a drop-down box, but 'The Internet' is the only connection available - my defulat connection is not even an option. I reverted to drivers that came with the modem, which places a shortcut to the proprietary dialer on the desktop. Using this, I was able to get connect to my ISP. I was then able to open IE and it worked fine. So, if anyone else is getting this problem, try using any dialer that came with your modem installation software, rather than relying on the connection set up in IE. |
| Guest | RE: Problem creating a PPPoA connection Alga i didnt have a problem using this card under beta 2 and used to connect to the net frequently with no problems using the default software that shipped with the CD. Now my problem is Rc1 wont install the drivers for some strange reason, and i have 2 unknown devices in my device manager. ( atm , base system device ). have you managed to get your card to work in rc1 ? lsonso2@hotmail.com "alga" wrote: > I am using a PCI ADSL (Conexant AccessRunner ADSL) under Vista Beta 2. The > connection details given to me by my ISP specifiy PPPoA so I have installed > the correct drivers for this, with no problems. I can see the System Tray > icon and use the Control Panel applet which both show the adapter has made a > successful connection. However, when I try to create a connection in > Internet Explorer, I only get the option to make a PPPoE connection. When I > try this it does not work. Diagnosing the problem gives a message to the > effect that my Local Network cable is unplugged, which does not apply to > PPPoA. > > So the problem is I can get a successful connection to broadband - I just > can't use it under IE. > > My questions are:- > > 1) does Vista support PPPoA, as it is not mentioned anywhere in Help (or in > these forums)? > > 2) If 1) is not relevant to the problem I am having, is there a way of > making IE 'recognise' the ADSL adapter under Vista? > > Thanks, > > alga |
| Guest | RE: Problem creating a PPPoA connection Dave, I've since switched to a Wireless ADSL Router which solved all my problems. I've not been able to download RC1 yet. Alga. "Dave" wrote: > Alga i didnt have a problem using this card under beta 2 and used to connect > to the net frequently with no problems using the default software that > shipped with the CD. > > Now my problem is Rc1 wont install the drivers for some strange reason, and > i have 2 unknown devices in my device manager. ( atm , base system device ). > > have you managed to get your card to work in rc1 ? > > lsonso2@hotmail.com > > "alga" wrote: > > > I am using a PCI ADSL (Conexant AccessRunner ADSL) under Vista Beta 2. The > > connection details given to me by my ISP specifiy PPPoA so I have installed > > the correct drivers for this, with no problems. I can see the System Tray > > icon and use the Control Panel applet which both show the adapter has made a > > successful connection. However, when I try to create a connection in > > Internet Explorer, I only get the option to make a PPPoE connection. When I > > try this it does not work. Diagnosing the problem gives a message to the > > effect that my Local Network cable is unplugged, which does not apply to > > PPPoA. > > > > So the problem is I can get a successful connection to broadband - I just > > can't use it under IE. > > > > My questions are:- > > > > 1) does Vista support PPPoA, as it is not mentioned anywhere in Help (or in > > these forums)? > > > > 2) If 1) is not relevant to the problem I am having, is there a way of > > making IE 'recognise' the ADSL adapter under Vista? > > > > Thanks, > > > > alga |
| Display Modes | |
| Problem in Creating Wireless Connection and File Sharing | Amit | Network & Internet | 9 | 02-04-2008 04:38 AM |
| Creating a desktop icons to enable/disable ethernet connection | Phisherman | Vista General | 0 | 12-16-2007 11:23 AM |
| Problems creating shortcut to dial-up ISP connection | vista neophyte | Vista installation & setup | 4 | 09-10-2007 09:10 AM |
| Creating a shortcut to a VPN connection | RMcCabe | Vista networking & sharing | 5 | 03-19-2007 04:23 PM |
| I have a problem creating a ODBC connection to a Foxpro Database!! | John C. Hill | Vista file management | 9 | 09-26-2006 02:02 PM |
