| | Vista Home and Ultimate on same machine I have both Vista Home Premiun and Ultimate on the same computer (don't ask!) - so is there a way I can uninstall Home Premium to free up more disk space? |
| | Re: Vista Home and Ultimate on same machine Hi Iain, Yes, but you wouldn't uninstall, you'd either delete the OS files or format the drive. First, you need to determine which drive is the system drive. If the Vista Home Premium volume is the system volume, then do *not* format it. Instead, simply boot into Ultimate, then remove the VHP installation folders on that volume (may require taking ownership of them). If it is not the designated system drive, then you can simply format it. Afterwards, run msconfig and delete the line that loads the unwanted OS installation on the boot tab. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org "Iain" <Iain@discussions.microsoft.com> wrote in message news:7AE01EBD-EAE8-4004-BA58-23C99A0F2EA2@microsoft.com... >I have both Vista Home Premiun and Ultimate on the same computer (don't >ask!) > - so is there a way I can uninstall Home Premium to free up more disk > space? |
| | Re: Vista Home and Ultimate on same machine "Iain" <Iain@discussions.microsoft.com> wrote >I have both Vista Home Premiun and Ultimate on the same computer (don't >ask!) > - so is there a way I can uninstall Home Premium to free up more disk > space? What's the system configuration, number of drives, types, and where is each OS installed? -- Rock [MS-MVP User/Shell] |
| Use XP Pro upgrade on a Vista Home machine ? | Vista General | |||
| Cannot activate my Vista Ultimate on new machine | Vista installation & setup | |||
| Vista Ultimate and running within a virtual machine... | Vista installation & setup | |||
| Vista Ultimate on 64-bit Machine | Vista General | |||
| Installing Vista Ultimate on more than one machine.. | Vista installation & setup | |||
