Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Solution to the Product Key problem.
Old 06-15-2006   #1 (permalink)
Bud
This is what I found, wrirren by Tim Sneath "Musings of a Windows Vista
Technical Evangelist".
Wednesday, September 21, 2005 2:02 PM tims
PDC05: Product Key Problems
Some people have experienced difficulties with activating the Windows Vista
builds that we distributed at the PDC. Please accept our apologies for this;
there's been a mismatch between the activation servers and the product key
that was handed out. It's embarrassing - we screwed up - we're sorry. So
here's the deal:
For Windows Vista Beta 1, use the following product key:
Q8WDJ-TR4KJ-X8WHM-GVGV3-H74C3
For Windows Vista Build 5219 (PDC CTP), use the following product key:
GKFV7-F2D9H-QKYXY-777P3-4M73W
If you are having problems activating either build, please try again
tomorrow. We are replicating the needed changes as we speak, but at this
point, not all the activation servers are updated.
Old 06-15-2006   #2 (permalink)
Andre Da Costa [Extended64]
Re: Solution to the Product Key problem.
That was for a very old build, like around build 5219 distributed at PDC
2005 and to Technical Testers.
Andre
Windows Connected | http://www.windowsconnected.com
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
"Bud" <Bud@discussions.microsoft.com> wrote in message
news:B0AF83B9-8775-456E-A183-F301053B3319@microsoft.com...
> Vista
> this;
> here's the deal:
Old 06-15-2006   #3 (permalink)
Jupiter Jones [MVP]
That is unlikely to be relevant to any Product key issues with Windows Vista
Beta 2.
Did you notice the date of the note?
Product Keys for older builds do not work on current builds.
I am also curious where you found this old information.
Jupiter Jones [MVP]
http://www3.telus.net/dandemar
http://www.dts-l.org
> Vista
> this;
> here's the deal:
Solved New Problem with Previous Solution General Discussion
My solution to this problem Vista mail
Using Vista x64.... need a solution for my problem Vista General
Printer problem and Solution Vista General
Possible Solution To Vista Problem Vista installation & setup
