Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Problem-MPU-401 Compatible MIDI Device
Old 04-30-2007   #1 (permalink)
MajorTom007
Just installed Vista and get a message that a driver can't be found for
MPU-401 Compatible MIDI Device. I don't know to what this refers. It says
it is from nvidia. I have Asus A8N-E mobo with Asus Geforce 7600, both
Nvidia. What drivers would I need and what device is this?
Old 05-01-2007   #2 (permalink)
xfile
Re: Problem-MPU-401 Compatible MIDI Device
I too searched high and low for this and it turned out to be the game
controller.
Refer to this article (PS: Use at your own risk ):
http://forums.creative.com/creativel...cending&page=1
It solve my yellow marked unknown device with the same message as MPU-401...
Hope this helps.
"MajorTom007" <MajorTom007@discussions.microsoft.com> wrote in message
news:77B03E39-6FD7-4672-8400-51FEC13C0DA1@microsoft.com...
> says
MIDI device Sound & Audio
Windows Vista and MPU-401 Compatible MIDI Device Vista hardware & devices
MPU 401 - Compatible MIDI Device (ASUS AN8-E) Vista hardware & devices
Windows Vista does not support MPU-401 Compatible MIDI Device Vista hardware & devices
