Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Right click on START/PROGRAMS not working
Old 05-04-2007   #1 (permalink)
cewrx7r1
After reloading Home Premium due to a non recoverable crash, I can not right
click on any label under START/PROGRAMS to delete it or even make a shortcut.
I have to go into MY COMPUTER or EXPLORER to do it.
How do I fix this?
Old 05-04-2007   #2 (permalink)
dean-dean
Re: Right click on START/PROGRAMS not working
Although this shouldn't affect All Programs in the Start Menu, it will
affect the icons in Start Menu's initial view: right click on the Start
Menu button, choose Properties, then choose Customize. Make sure the
"Enable context menus and dragging and dropping" item has a checkmark next
to it.
"cewrx7r1" <cewrx7r1@discussions.microsoft.com> wrote in message
news:6F67CE94-0EF7-47BD-856B-EFE99D8C2504@microsoft.com...
> right
> shortcut.
> How do I fix this?
Old 05-04-2007   #3 (permalink)
Chad Harris
Hi cewrx7r1-
1) Try this reg tweak from Kelly (whose site seems to be off line--I had to
use a web archive to reach it):
http://web.archive.org/web/200604241...ontextmenu.reg
Click it>run>apply
2) Try SFC:
Type cme in Search Box>rt.click when pops up>run as admin>at prompt type sfc
/scannow.
3) If you have a restore point try SR.
CH
> right
> shortcut.
> How do I fix this?
Old 05-04-2007   #4 (permalink)
Chad Harris
Also see this which could fix it from Ramesh's excellent site which also
required me to use a web archive:
http://web.archive.org/web/200605160...RightClick.htm
CH
> right
> shortcut.
> How do I fix this?
Old 05-04-2007   #5 (permalink)
cewrx7r1
This worked perfectly, thanks!
> to it.
> > right
> > shortcut.
> > How do I fix this?
programs stop working before they start. Vista performance & maintenance
Start Button + right Click Desktop not working General Discussion
When I click start, games, then click on a game I get this error message: Vista General
Disabling Start-up Programs not working! Help! Vista performance & maintenance
Start/All Programs Menu shortcuts not working Vista General
