Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Installation reboot problem
Old 06-19-2006   #1 (permalink)
lee
I'm trying to install x64 on an IDE hd on my dfi nf4 ultra. The installation
goes ok through all the steps until it needs to reboot. When it boots it
gets to the end of the post screen and thats it. The curser blinks and the
hd light is on but nothing happens. I've left it like this for hours but it
stays the same. I've tried reinstalling it a few times but it's always the
same. When I do reinstall it, it shows there are windows files on the drive
and asks to rename them as old files but says nothing about a previous
installation being in progress. Loading into xp on my sata drive I can see
all the vista files.
Some people have suggested turning off raid and sata but I have already done
this.
Old 06-19-2006   #2 (permalink)
droid
Re: Installation reboot problem
it's a PATA drive you're trying now ? Unless you get better ideas, here's
some guess work of what might help:
1 Try see if there's BIOS updates then try reinstall if you updated bios
2 (if you don't mind losing all data on it) Try clipping the drive to 32 GB
with jumper on the back. Delete the some 100 first "physical" sectors on it
with disk editor. now try reinstall with no other hdd attached
since this is a beta test i'd rather though have the setup as normal as
possible, let the stuff fail, gather all info possible and logs then fire
off a well written report with Beta Client...
"lee" <lee@mail.com> wrote in message
news:O%23Tguq6kGHA.4776@TK2MSFTNGP05.phx.gbl...
> installation goes ok through all the steps until it needs to reboot. When
> it boots it gets to the end of the post screen and thats it. The curser
> blinks and the hd light is on but nothing happens. I've left it like this
> for hours but it stays the same. I've tried reinstalling it a few times
> but it's always the same. When I do reinstall it, it shows there are
> windows files on the drive and asks to rename them as old files but says
> nothing about a previous installation being in progress. Loading into xp
> on my sata drive I can see all the vista files.
> done this.
Installation reboot loop Vista installation & setup
Installation reboot loop Vista General
Vista 64 Installation Problem-Sent to x: at reboot Vista General
