| | Help with downloading english 64 Bit vesion I am having problems downloading the English 64-Bit version from http://download.windowsvista.com/pre...4/download.htm I am using GetRightPro but the server disconnects at 99% and won't resume. Help please |
| | Re: Help with downloading english 64 Bit vesion My guess is that 99% is 4.00GB and the image is 4.01GB. Is the hard drive you are saving it to FAT32? That would explain the error. You could also try to use the MS download manager as the GetRight download manager may not be capable of downloading a file larger than 4GB. ---------- Mark Dietz PROnetworks <http://www.pro-networks.org> neon3849uk wrote: > I am having problems downloading the English 64-Bit version from > http://download.windowsvista.com/pre...4/download.htm > I am using GetRightPro but the server disconnects at 99% and won't resume. > Help please > |
| | Re: Help with downloading english 64 Bit vesion My Harddrive is 120G SATA drive, formatted NTFS. I have used Getright to download larger files than 4G without problems. I can't seem to get the MS download manager to work............ "Mark Dietz" wrote: > My guess is that 99% is 4.00GB and the image is 4.01GB. Is the hard drive you > are saving it to FAT32? That would explain the error. You could also try to use > the MS download manager as the GetRight download manager may not be capable of > downloading a file larger than 4GB. > ---------- > Mark Dietz > PROnetworks <http://www.pro-networks.org> > > neon3849uk wrote: > > I am having problems downloading the English 64-Bit version from > > http://download.windowsvista.com/pre...4/download.htm > > I am using GetRightPro but the server disconnects at 99% and won't resume. > > Help please > > > |
| English LIP | Vista General | |||
| Vista non-English upgrade to Vista English | Vista installation & setup | |||
| Non US English | Live Mail | |||
| English?????? | Vista General | |||
| US English XBOX 360 + US English Vista Beta 2 = Broken Media Cente | Vista General | |||
