Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - help please on macromedia flash player....
Old 06-28-2007   #1 (permalink)
cramerswife
i need to know how to install the macro media flash player it wont let me i
recently de installed java but nothing seems to be workin? i need some help
here
Old 06-28-2007   #2 (permalink)
Carey Frisch [MVP]
Re: help please on macromedia flash player....
Download the standalone version of Flash Player from here:
http://www.softwarepatch.com/network...nload-security
Carey Frisch
Microsoft MVP
Windows - Shell/User
---------------------------------------------------------------------------Â*-----
here
Old 06-28-2007   #3 (permalink)
cramerswife
RE: help please on macromedia flash player....
wich one do i get?
> here
Old 06-28-2007   #4 (permalink)
dean-dean
For Internet Explorer, this is the latest version (Adobe Flash Player
9.0.45.0):
http://download.macromedia.com/get/f...r_active_x.exe
"cramerswife" <cramerswife@discussions.microsoft.com> wrote in message
news:7FB6D14C-1FB4-4E2D-96F3-12E03EE4E6E5@microsoft.com...
> wich one do i get?
>> me i
>> help
>> here
Old 06-28-2007   #5 (permalink)
Carey Frisch [MVP]
http://www.softwarepatch.com/internet/flash.html
Carey Frisch
Microsoft MVP
"cramerswife" <cramerswife@discussions.microsoft.com> wrote in message news:7FB6D14C-1FB4-4E2D-96F3-12E03EE4E6E5@microsoft.com...
wich one do i get?
> here
Old 09-05-2007   #6 (permalink)
Jasmine
> Carey Frisch
> Microsoft MVP
> here
Old 09-05-2007   #7 (permalink)
Jasmine
I have Vista and tried to download Flash via the Quia test site to take an
online exam. Then I tried going to Adobe. Spent 4 hours unsuccessfully.
Then I went to Best Buy where I bought my compuer (which is 2 months old) and
they tried for 2 hours unsuccessfully. They told me that Vista has known
compatability problems with Flash. They also said they only way to rectify
the problem was to reformat the hard drive and start over. They said they
said that by initially trying to download through a third party (which may
have had an older version) could have corrupted something that was not
fixable. By reformatting etc. I would loose all my software that I got
through my work (multiple user use) and I no longer work there or have access
to office which means I would not have to buy microsoft office, plus they
would charge me the "rebuild" and backing of my information. I bought my
computer on a one years financing and can't afford to spend several hundred
dollars fixing something I haven't even paid for yet.
I have contacted Microsoft, HP and Adobe and after numerous more hours was
told they don't know what the problem is.
I uninstalled any previous attempts and then tried your standalone patch,
but it does not work either.
Do you have any other solutions.
I am at my wits end.
> Carey Frisch
> Microsoft MVP
> here
Old 09-05-2007   #8 (permalink)
Carey Frisch MVP]
Right-click on the IE icon located on the Taskbar and select
"Run as administrator". Then visit:
http://www.adobe.com/shockwave/downl...ShockwaveFlash
and click on "Install Now".
> Carey Frisch
> Microsoft MVP
> here
Old 09-05-2007   #9 (permalink)
John Barnes
Did you run the uninstall program first, before you installed the download
version?
"Jasmine" <Jasmine@xxxxxx> wrote in message
news:E575C5BE-F8D7-4B37-ACB8-C87BF6F5314C@xxxxxx
Quote:
> Hi,
> and
> rectify
> access
> hundred
>> Carey Frisch
>> Microsoft MVP
>> me i
>> help
>> here
Old 09-05-2007   #10 (permalink)
Jasmine
yes, then shut-down and restarted. Did this several times.
"John Barnes" wrote:
> version?
Quote:
> > Hi,
> > and
> > rectify
> > access
> > hundred
> >> Carey Frisch
> >> Microsoft MVP
> >> me i
> >> help
> >> here
MacroMedia Flash Player. Vista General
Macromedia Flash Player are not runnning? Vista hardware & devices
Macromedia flash player Vista General
Adobe Macromedia Flash Player Won't Install Vista General
Installing Macromedia Flash Player. Vista General
