Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista Tutorial - XP Pro 32-bit to Vista Home Premium 64Bit
Old 06-30-2007   #1 (permalink)
kryptik
Guest
My brother has Vista Ultimate, so I took advantage of the Family discount and
got the Home Premium upgrade. So is it possible to upgrade from XP Pro 32
bit edition to Vista Home Premium 64-bit edition?
Thanks
Old 06-30-2007   #2 (permalink)
Paul Smith
Guest
Re: XP Pro 32-bit to Vista Home Premium 64Bit
"kryptik" <kryptik@discussions.microsoft.com> wrote in message
news:5A97E22D-605F-4A04-9264-400655BC617E@microsoft.com...
> and
It'll require a clean install (although it doesn't have to wipe the hard
drive).
Paul Smith,
Yeovil, UK.
Microsoft MVP Windows Shell/User.
http://www.dasmirnov.net/blog/
http://www.windowsresource.net/
*Remove nospam. to reply by e-mail*
Old 06-30-2007   #3 (permalink)
kryptik
Guest
> > and
> drive).
> Paul Smith,
> Yeovil, UK.
> Thanks, I found the answer here aswell, if anyone has any other questions...
http://windowshelp.microsoft.com/Win...c8a701033.mspx
Problems with Vista Home Premium 64bit Vista performance & maintenance
Solved Vista Home Premium 64bit Problem General Discussion
Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media Vista installation & setup
Vista home premium 64bit Drivers
Have 32bit OEM Vista Home Premium - Need 64bit Drivers
